Browse Forums Building A New House 1 May 11, 2013 2:47 pm Our neighbour's house is quite well set back from the street. We are building at minimum distance from the street and their power lines cross over where we are building. I am assuming they will have to pay to move them? They could put an electricity pole in their front yard and connect from that. Does anyone have any thoughts on a good process to get them to do this? I doubt they'll just agree if I ask them. Re: Neighbour's power lines interfering with our build 2May 11, 2013 5:33 pm Have you spoken with origin energy about this? Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Neighbour's power lines interfering with our build 3May 11, 2013 7:03 pm Unless the power company have an easement over your land you can tell them to remove the cables. Its up to the power company to serve each property without infringing on your land, or the space above it. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Neighbour's power lines interfering with our build 4May 12, 2013 6:00 pm LOL It didn't occur to me to ring the power company. I will ring and ask them. It wouldn't be origin though, am in Sydney. Thanks for your replies. Re: Neighbour's power lines interfering with our build 5May 12, 2013 9:28 pm The power lines can cross your property if that is the only access point for your neighbour's service AND the cables clear a minimum height ( which I am unaware of the exact height in your area) and obviously the power company concerned will be able to clarify. Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Neighbour's power lines interfering with our build 6May 22, 2013 7:17 pm Well I rang AusGrid and they basically told me stiff cheese - they have the right to pass their electricity lines over my land and that they've been there a long time and legislation says its "automatic easement" even though an easement might not show up on my title. If I want to move it I have to pay for it. I'm quite upset about it all as looking at other people's posts on the internet, others have been able to have them moved for free. Apparently the cost can run up to $10,000. (haven't verified this). The street power pole is in front of my house, and its the nearest to my neighbour. They are so far back it'll need a private pole to remove them from my land. They didn't tell me anything about minimum height. They didn't even ask for the address. Re: Neighbour's power lines interfering with our build 7May 22, 2013 8:54 pm Have you tried ringing the Energy Ombudsman? Deemaree Kyndylan Capers: viewtopic.php?f=36&t=46852 My blog: http://www.sufficientlysufficient.blogspot.com/ Re: Neighbour's power lines interfering with our build 8May 22, 2013 9:08 pm Not yet Deemaree, thanks for the tip. I'm just unhappy as it will take $$ away from my all important build! Re: Neighbour's power lines interfering with our build 9Oct 21, 2015 8:52 pm Mrs Brown Bear Not yet Deemaree, thanks for the tip. I'm just unhappy as it will take $$ away from my all important build! Hi, How did you eventually address this issue? I'm facing a very similar, but even worse problem in my land which there're two cable lines hanging over my front yard cross driveway with fairly low height to my neighbor's house. I'm not sure if it's power cable, but I'm guessing it'll be equally difficult. Evening, Had my 3 month maintance done on my new place. Most things are fixed to ok standards, but im not sure about the visible joins in my plaster wall. There was 2… 0 4605 I like the bobcat idea - not too dear to hire either. Before doing that, maybe advise them you intend having all their stuff moved in the next 48 hours. Any damage or… 10 8552 Has anyone used XCEM Alphafloor concrete panels for subfloor and would recommend them over other subfloor options (Hebel Powerfloor,… 0 4257 |
