Browse Forums Building A New House 1 May 09, 2013 9:38 pm Hi guys, I want to know how bad is it to build in wet season in adelaide? Do I need delay my building until sep or oct? Hopefully, our plan will be approved by council end of this month (May). I heard something about avoiding build in wet season before. welcome, someone who build in wet season give me some ideas. Thanks Re: Do i need worry about the coming wet season? Adelaide 2May 09, 2013 9:51 pm To give you a bit of an indication... My trenches were dug July 2nd 2005. And I had handover November 25th. So, a 4.5 month build, In a regional area... Didn't really have many delays at all. All the delays were with the council stuff leading up to it! I can't remember what the weather was like, but I do know that there were rainy days. Once the roof is on, the weather isn't that much of an issue in regards to delays, and it takes no time for the framework and bricks to happen... So I wouldn't get too worried. It didn't affect my build in the slightest! Spring is traditionally really rainy as well in Adelaide, so you could argue not to do it then either... Same with the heat of summer and the New Years delay when work stops in Dec/Jan. So effectively if you delay your build till October, you'll have work stop completely mid December till Mid Jan when the building industry grinds to a halt for Christmas. That will be more frustrating. Just my 2c anyway. All the best with your upcoming build Thread: viewtopic.php?f=31&t=66299 Slab: 16/6/14 Frame: 4/7/14 Roof: 22/7/14 Lock Up: 20/8/14 Fixing: 26/8/14 PCI: 9/10/14 Handover: 20/10/14 Re: Do i need worry about the coming wet season? Adelaide 3May 09, 2013 10:07 pm deluxes To give you a bit of an indication... My trenches were dug July 2nd 2005. And I had handover November 25th. So, a 4.5 month build, In a regional area... Didn't really have many delays at all. All the delays were with the council stuff leading up to it! I can't remember what the weather was like, but I do know that there were rainy days. Once the roof is on, the weather isn't that much of an issue in regards to delays, and it takes no time for the framework and bricks to happen... So I wouldn't get too worried. It didn't affect my build in the slightest! Spring is traditionally really rainy as well in Adelaide, so you could argue not to do it then either... Same with the heat of summer and the New Years delay when work stops in Dec/Jan. So effectively if you delay your build till October, you'll have work stop completely mid December till Mid Jan when the building industry grinds to a halt for Christmas. That will be more frustrating. Just my 2c anyway. All the best with your upcoming build Thanks deluxes, I am more worry about the quality of building, liking the wet footing, wet timber frame Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9075 Chemtrails, only the most disproven conspiracy theory in the history of conspiracy theories. You've gone in the deep end, drowned, and are now a mindless bloated… 5 86574 Hi When it rains in a particular direction water comes through the security door. It hits the main door and the bottom swells and jams. There is already a cover over the… 0 38446 |
