Browse Forums Building A New House Re: Arden Developments 1981Oct 25, 2017 7:17 pm Unfortunately nobody checks and i panicked so much that after frame and before plaster , i i was check and telling my SS that water pipes are too close to the studs and nail guns will hit. But they mark them with pink spray paint before plastering. Gas is normally ok as it runs over the roof or between the joists. I would take lot of photos while frame stage and show it to trades later , if these some work or repair needs to be done. Rest , hope all goes well. I am hoping my comissioning of HWS and GAS and A/c goes well , fingers crossed. Re: Arden Developments 1982Oct 25, 2017 7:24 pm gopalc Unfortunately nobody checks and i panicked so much that after frame and before plaster , i i was check and telling my SS that water pipes are too close to the studs and nail guns will hit. But they mark them with pink spray paint before plastering. Gas is normally ok as it runs over the roof or between the joists. I would take lot of photos while frame stage and show it to trades later , if these some work or repair needs to be done. Rest , hope all goes well. I am hoping my comissioning of HWS and GAS and A/c goes well , fingers crossed. Thanks Gopalc - finally ur wait is over - so when r u moving in follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Arden Developments 1983Oct 25, 2017 7:30 pm Almost there, awaiting for last set of defects to be resolved and settlement to happen. Then the driveway and move in after that. Lot to be done after handover. Arden has resolved most of big ones i.e our kitchen overhead and buttler all cabinet doors were wrong grain and there was over mount sink instead of undercount specified in colour selection. Both have been fixed now. Re: Arden Developments 1984Oct 25, 2017 7:39 pm gopalc Almost there, awaiting for last set of defects to be resolved and settlement to happen. Then the driveway and move in after that. Lot to be done after handover. Arden has resolved most of big ones i.e our kitchen overhead and buttler all cabinet doors were wrong grain and there was over mount sink instead of undercount specified in colour selection. Both have been fixed now. are you putting the driveway yourself of thru Arden follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Arden Developments 1989Oct 25, 2017 7:46 pm Ya, thats correct , we had butler sink as overmount with side drip tray, They took by mistake as both same as over mount.... whole bench top stone was replaced to fix that.... that took lot of time and costly ... Re: Arden Developments 1990Oct 25, 2017 8:01 pm gopalc Ya, thats correct , we had butler sink as overmount with side drip tray, They took by mistake as both same as over mount.... whole bench top stone was replaced to fix that.... that took lot of time and costly ... U mean you had pay to get the stone bench top replaced - how much did it cost. Are you too going with aggregate driveway and yes and front view photo of the house from the road follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Arden Developments 1991Oct 25, 2017 8:39 pm No, we didn't have to pay, it was clearly mistake from trades. My SS was good and he got it done finally, although , there was arguments they had to deal with ... Exposed aggregiate ( light grey similar to what Jeeta got it) , I am getting all done all around the house and behind the garage we have roller gates and i am getting that whole area Exposed aggregate , so that there is no mess and water drains and we can park car, in case we need it. I am also going to put garden shed, water tank and bins on this side of the house and then spend time and energy on other side to make it entertainment side. I am getting retaining wall ( stone look sleepers) and grass done now . Security camera , i am doing it myself from HIKvision ( all ready set to go ) with intercom and monitor from HK as well. Alaram system and outdoor camera with cloud recordings. Re: Arden Developments 1992Oct 25, 2017 9:16 pm gopalc No, we didn't have to pay, it was clearly mistake from trades. My SS was good and he got it done finally, although , there was arguments they had to deal with ... Exposed aggregiate ( light grey similar to what Jeeta got it) , I am getting all done all around the house and behind the garage we have roller gates and i am getting that whole area Exposed aggregate , so that there is no mess and water drains and we can park car, in case we need it. I am also going to put garden shed, water tank and bins on this side of the house and then spend time and energy on other side to make it entertainment side. I am getting retaining wall ( stone look sleepers) and grass done now . Security camera , i am doing it myself from HIKvision ( all ready set to go ) with intercom and monitor from HK as well. Alaram system and outdoor camera with cloud recordings. Building the Arden Votivo 43 Follow me here: https://forum.homeone.com.au/viewtopic.php?f=31&t=88553 Re: Arden Developments 1993Oct 25, 2017 9:29 pm I got it from ebay and it took time to setup at my home to understand the whole system and recording etc. I bought camera two firstly and then added some more and some indoor ones. its all simple stuff, plug and play. its working fine but i need to integrate all once i get the handover. Did some research on Dahua as well but , looks like HIKVision is more common with local installers and worst case , you can take help from proffessionals. Its just simple plug in cat 6 cabling and hooking it to your wifi router.It all works fine. Re: Arden Developments 1994Oct 25, 2017 9:30 pm gopalc I got it from ebay and it took time to setup at my home to understand the whole system and recording etc. I bought camera two firstly and then added some more and some indoor ones. its all simple stuff, plug and play. its working fine but i need to integrate all once i get the handover. Did some research on Dahua as well but , looks like HIKVision is more common with local installers and worst case , you can take help from proffessionals. Its just simple plug in cat 6 cabling and hooking it to your wifi router.It all works fine. Building the Arden Votivo 43 Follow me here: https://forum.homeone.com.au/viewtopic.php?f=31&t=88553 Re: Arden Developments 1996Oct 26, 2017 7:34 am gopalc Almost there, awaiting for last set of defects to be resolved and settlement to happen. Then the driveway and move in after that. Lot to be done after handover. Arden has resolved most of big ones i.e our kitchen overhead and buttler all cabinet doors were wrong grain and there was over mount sink instead of undercount specified in colour selection. Both have been fixed now. Awesome gopalc!! Hope all goes well looking forward to pics of your beautiful home!! _________________________________________ Regards Manj https://forum.homeone.com.au/viewtopic.php?f=31&t=88256 Re: Arden Developments 1997Oct 26, 2017 9:55 am Morning all, has anybody selected carpet and timber directly from FlooringXtra and taken the samples for the colours? did a browse on Flooringxtra and I found that their laminate/timber options are greater than PTF. thanks _________________________________________ Regards Manj https://forum.homeone.com.au/viewtopic.php?f=31&t=88256 Re: Arden Developments 1998Oct 26, 2017 11:19 am Not 100% sure Manj but I would have thought you would have to select from PTF but as they also use Flooringxtra there may be a chance. You can ask your CA prior to colour app, they can find out for you. Re: Arden Developments 1999Oct 26, 2017 11:22 am Ezza78 Not 100% sure Manj but I would have thought you would have to select from PTF but as they also use Flooringxtra there may be a chance. You can ask your CA prior to colour app, they can find out for you. Thanks Ezza78... have emailed the CA ... hopefully its possible _________________________________________ Regards Manj https://forum.homeone.com.au/viewtopic.php?f=31&t=88256 Re: Arden Developments 2000Oct 26, 2017 11:24 am Ezza78 Not 100% sure Manj but I would have thought you would have to select from PTF but as they also use Flooringxtra there may be a chance. You can ask your CA prior to colour app, they can find out for you. i thought u would busy watching the site cut today:) follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 |
