Browse Forums Building A New House Re: 1.6m fall. split-level or cut-and-fill? Help me! 4Apr 23, 2013 3:25 pm Building the Cosmos with New Generation. Site scrape and pegs - 25 Oct '13. Our Build Thread: viewtopic.php?f=31&t=64306 Re: 1.6m fall. split-level or cut-and-fill? Help me! 6Apr 29, 2013 3:52 pm I am biased, but I would suggest a split level as your first port of call. We are building a split level and our block had a side slope as well as a slope from back to front..... we absolutely LOVE what we have come up with, and it worked out cheaper than just filling the block due to the extra retaining walls, concrete, etc that would have been needed to stabilise.... in comparison, our block has been nicknamed "the mansion" because it looks so big in comparison to some of the single story homes in the street. It really comes down to what design features you do/dont want in your home, and work from there..... but i do love split level, and a couple of stairs here or there isnt much, but it adds so much character and also separates areas - so if anything, can make the area seem bigger as it gives you more defined living areas.... Let us know what you decide on either way.... or put some plans up and we can all throw some ideas or suggestions at you for split/single level homes that would work. Cheers Blog: http://matt-and-jo.blogspot.com.au/ Purchased Block: August 2011, Block Settled: Dec, 2011 Contract Signed: 28/6/12, Site Works Started: 9/11/12 Re: 1.6m fall. split-level or cut-and-fill? Help me! 7Jul 25, 2013 9:59 am Also, and sorry if this was mentioned but I couldn't see it - do you have any views? It may be worth building the house up if so as to get the most out of the view. If not then I guess it doesn't matter, do the most economical option. My Hamptons build (completed): viewtopic.php?f=31&t=63370 Moved in Wednesday 11th Dec 2013 Front landscaping completed June 2016 1 421 For those following along, the engineers have kindly come to the party and will be implementing a solution that should ensure adequate fall to the house connection. This… 8 2615 Looks like it, the only time a 6m cut would occur it if the builder cuts straight between those opposite corners. But if you have got the DA drawings and minimal… 3 538 |
