Browse Forums Building A New House 1 Apr 18, 2013 7:32 pm So, I have a choice between two designs that I like in my price range The first has an alfresco to the back, following on to a 5 metre backyard The second has a side alfresco off the meals/family area. The 3 back bedrooms are at the back of the house. heres the plans Any suggestions/comments would be welcome http://www.8homes.com.au/home-designs/s-three/ http://www.8homes.com.au/home-designs/s-five/ Re: alfresco to side or back 2Apr 18, 2013 7:45 pm my choice would be the first one that flows from family room to backyard makes it feel more spacious Re: alfresco to side or back 3Apr 18, 2013 7:51 pm Whichever one doesn't face west or south. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: alfresco to side or back 4Apr 18, 2013 7:57 pm First i'd would want to know where north is before choosing on a location for alfresco as if its facing the west or north/west side it will get the hot summer sun. With no information other than the plans I would choose the second location on the side of the house as it seems to be more shielded from the weather/sun. Re: alfresco to side or back 5Apr 19, 2013 8:15 am Would be good to know what the orientation of your block is. In saying that I would go for the first one. The alfresco on the second is quite deep and being only 3m off the boundary would be quite dark no matter what the orientation is. It's also 'tucked away' from the entertainment hub of kitchen/dining/family, also if you are entertaining you need to walk through everything to get tot he bathroom/toilet. The first design is more open plan and in my opinion flows better. Re: alfresco to side or back 6Apr 19, 2013 11:26 am I would go with the first one... You will only have a 5m backyard in either design, so the backyard could become an extension of the alfresco. You can reverse the design to take advantage of the sun. When we were deciding on a design, it was a similar decision. I think we will use our backyard a lot more now then if the alfresco was in the middle. Plus when it's built, it's a bit deceiving, our alfresco is 6x3m. Seeing it built, It will just fit an eight seater table and chair with moving space comfortably but butting up to the backyard I plan on extending it with paving or concreting. Make it feel a lot more spacious. Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: alfresco to side or back 7Apr 19, 2013 11:51 am Orientation of you block is probably the key consideration for the design you choose. No point in having an alfresco that is open and spacious if you can't use it because of a harsh western outlook, or it gets no sunlight whatsoever. In regards to useability, I find an alfresco area that sits off a kitchen/dining area works much better than a living area. This is in regards to entertaining etc. With the plans show, I like the openness of the alfresco of plan 1, but the placement of the alfresco in relation to kitchen dining of plan two. But as others have pointed out - plan one seems to flow much better. Re: alfresco to side or back 8Apr 19, 2013 12:21 pm I'd go the first one seems to flow a bit better - one other thing though Could you move the front entry to the middle at the front - between the master suite and garage, that was you could also have an door straight into the house from the garage. Our Custom Dale Alcock build in the Village at Wellard https://forum.homeone.com.au/viewtopic.php?f=31&t=78620 Re: alfresco to side or back 10Apr 19, 2013 2:24 pm i like the floor plan of the second one better, guess i am a bit different to everyone else. Re: alfresco to side or back 11Apr 19, 2013 8:34 pm Wellard2ndTimers I'd go the first one seems to flow a bit better - one other thing though Could you move the front entry to the middle at the front - between the master suite and garage, that was you could also have an door straight into the house from the garage. yes My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6936 Hi HomeOne, I'm in the midst of landscaping a cat run down the side of my house, and the recent rains have me wondering if I need to install some sort of drainage. I've… 0 12290 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 20908 |
