Browse Forums Building A New House Re: Boral Storm brick 2Apr 23, 2013 8:34 am We are using it as our feature brick. If you watch our thread by next week these should be complete Also, http://inthewoodswithcaution.blogspot.com.au/ if you have not seen this already. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7815 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6845 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10474 |
