Browse Forums Building A New House 1 Apr 08, 2013 8:37 am I'm trying to incorporate a bathtub into the ensuite. The only design we think that will fit into a narrow-ish space is to combine our wet area. I can't work out how to add a picture so I'll have to try and describe it. So, I will have a large glass panel, behind the glass I will have the shower head, next to the shower space I will have an inbuilt bathtub at the end of the room. Basically it's a combined wet area. Has anyone else built this design and if they have does it work for them? hard to clean? moisture issues? Also do you know if I can separate my water lever to my shower head? I mean can I have my lever on a different wall to my shower head? This is probably a question for my builder but just wondering if anyone has done it? Re: Wet area in ensuite 2Apr 08, 2013 9:58 am Quote: I can't work out how to add a picture so I'll have to try and describe it. How to post a photo... viewtopic.php?f=6&t=42169 A few other guides here on the forums too. It just makes it so much easier. "A picture tells a thousand words" etc etc. Stewie Re: Wet area in ensuite 3Apr 08, 2013 10:14 am If the shower area is step less then I'm pretty sure you would have to tank the whole room, which might include the hob around the bath. Is your design set yet ? Re: Wet area in ensuite 6Apr 08, 2013 10:42 am Hi screen7. Initial drawings are getting done by architect as we speak so we can see dimensions and if it's going to fit. We will probably get a small step down into the shower space. Builder said it's do-able and didn't seem to flinch when I showed him the picture. Just wanted an opinion from someone doing the same design. Not sure if there are any major problems later on with the wet area. Re: Wet area in ensuite 8Apr 08, 2013 12:25 pm Close MrsG but not quite. Go to your photobucket library page and click on the photo in question. On the right hand side click on the little arrow next to the Image Links heading then scroll down to the IMG code and click on it which means you have copied it to the clipboard. Come back to this forum and paste it into your post. You should see something like [img]Your%20photo...[/img] and voila the picture appears on these forums. Stewie Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And as per screen7's post you should waterproof the whole bathroom . Re: Wet area in ensuite 10Apr 08, 2013 4:39 pm Yes I was going to ask if you had considered something like above . We have a freestanding bath but the glass separates it from the shower. Even so we tanked the whole room. One thought though if you do go for a free standing bath make sure you have good clearance all the way round for cleaning. We had a claw foot bath in our pre renno home against a wall, nightmare to clean behind, and when I removed it boy was it scarey what was hidden. We immediately changed our floor plan to put the bath away from a wall, mind you our bathroom is huge so we could afford the wriggle room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Wet area in ensuite 11Apr 08, 2013 5:24 pm Those pics are sweet! Like the idea - will be following to see how it pans out. What did you get quoted to go hobless? Assuming you are hobless? Building with 101 Residential in Falcon. Re: Wet area in ensuite 12Apr 09, 2013 6:44 am Yes. Like travisaus layout. I was going to get a freestanding bath but with the narrow room I would have had to have the bath up against the walls therefore I would have had the cleaning issues in behind the bath tub. So we are thinking having a bath in a hob at the end of the room. Really depends now how much the builder will charge to water proof the whole room. If it blows our budget than we might be redesigning the ensuite again. Will keep you post. Thanks for all the replies. I love your bathroom screen7. Re: Wet area in ensuite 13Apr 09, 2013 6:47 am Hi Homebody99. Our builder didn't say it was going to be more money when I showed him this plan for our ensuite. He just said that they can do it. He might now when I ask him to water proof the whole room. Our plans are currently getting drawn up so will let you know. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16635 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3688 Thanks for the suggestion. The space between shower and sinks was too tight. I agree about the toilet location. So I have tried two other options: The lower one is… 3 6185 |
