Browse Forums Building A New House 1 Apr 05, 2013 9:04 am I have to get a "Land capability assessment" done to apply for planning permission for a 7 acre block out near Moriac (Geelong). Can anyone recommend someone to do this, (cheaply). I see all sorts of prices for soil tests, some running into the thousands, and here I thought it would only be a couple of hundred!! When did Oz get so expensive? Cheers Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18261 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6447 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24875 |
