Browse Forums Building A New House Re: Custom Build in Hills District - Home Theatre Screen up 161Jul 21, 2014 8:56 pm Have not had time to do anything else. The only significant thing that has been done is to have the garage floor painted. The main purpose is for ease of cleaning by reducing concrete dust. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District - Home Theatre Screen up 162Jul 27, 2014 9:51 pm What a great idea! Did you do this yourself? Is it expensive? Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Custom Build in Hills District - Home Theatre Screen up 163Jul 27, 2014 9:56 pm I love it . I really won't my partner to do ours once we get the crap out . Iv never had a door accessing my carport from inside my house . I think it needs to look good . But trying to convince my partner . Do you need to paint it like every couple of years Re: Custom Build in Hills District - Home Theatre Screen up 164Jul 27, 2014 9:57 pm I had it done as part of the build, however builder wasn't able to schedule it before I moved in. They scheduled it with short notice a few months after I moved in. It was done with Berger paving paint. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District - Home Theatre Screen up 165Jul 27, 2014 10:01 pm It's pretty hard-wearing. I let it dry for about 3 days before I put the car in. I'm hoping that it will last 5 years before a recoat. They did 2 coats. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District - Home Theatre Screen up 166Jul 28, 2014 12:17 pm Good Idea i wonder if it will cost much? Burbank Custom DS 23/01 Slab 14/02 Frame 15/04 Lockup 13/06 Fixing 02/09 PCI 11/09 Settlement My Build:viewtopic.php?f=31&t=68855 Blog:http://ourmentone3850.blogspot.com.au Re: Custom Build in Hills District - Home Theatre Screen up 167Feb 23, 2015 6:36 pm I finally found the time to have some canvases printed for my wall niches. It was tricky finding pics to suit a narrow / tall space. I also thought it important the pics fit a theme. These are nice colourful gums cropped from a single photo. If planning niches, it is worth thinking carefully what size they will be. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District 169Mar 12, 2015 6:31 pm More work done on the backyard. Plantation shutter before / after Fencing tidy-up Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District 171Mar 12, 2015 6:36 pm 1st_HomeBuyer Looks quite good! Thanks! Quite a bit more work to happen here. Watch this space. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District 172Mar 12, 2015 6:36 pm Hey Mate The projector you got is throwing image on the wall?? Or is it some kind of board etc?? Cheerio OB! Re: Custom Build in Hills District 173Mar 12, 2015 6:37 pm Yeah i am following your post mate Cheerio OB! Re: Custom Build in Hills District 174Mar 12, 2015 6:43 pm 1st_HomeBuyer Hey Mate The projector you got is throwing image on the wall?? Or is it some kind of board etc?? The screen is from these guys: 100" TCC 16:9 Fixed Frame projector screen The screen is made from an extruded aluminium frame covered with felt. A heavy vinyl sheet is then stretched onto pegs on the frame. I'm very pleased with the quality of construction. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District 175Mar 12, 2015 6:46 pm What about sound system? Which company did you use for that? I am a freak when it comes to sound... Cheerio OB! Re: Custom Build in Hills District 176Mar 12, 2015 7:10 pm In the Home Theatre my speakers are Q-acoustics in-wall speakers for a 7.2 setup In the Living-room I have Q-acoustics in-ceiling speakers for a 9.2 setup ( 2 of these speakers in the alfresco ) I have Q-acoustics sub-woofers in both areas. The speakers were through Cable connection, although one of the subbies and the 7 in-wall speakers were actually a competition prize Projector is also from Cable Connection. I arranged separately for a contractor to install the speaker wiring before the plaster went in and then fit the speakers in the walls / ceilings once the plaster was painted. I had them leave bare cables pocking out of the walls. Get your builder's electrician to run 50mm PVC pipe in the ceiling and down the front wall of the home theatre to use as conduit for the cabling. Make sure they use a generous turn radius on any corners. The electricians also installed a TV wall mount in the living room and the roof mounting bracket for my projector. I also had them run lots of extra network ports into the Home Theatre and Living Room. Quad ports at each location from memory. ( the electricians stuffed that up and used tight elbow fittings - I had to buy HDMI over CAT 5/6 converters since I could not pull the HDMI cables through the tight turns in the pipe ) I had a home theatre installer wire up and install the wall plates for the speakers. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Re: Custom Build in Hills District 177Mar 12, 2015 7:16 pm This is freaking awesome Loved the clean setup details... i really love clean sound setups and your setup sounds one of them. Kudos Mate! Enjoy Cheerio OB! Re: Custom Build in Hills District 178Mar 14, 2015 6:50 pm Timber screen was constructed today. With some barbed wire, my backyard will look like a POW camp. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 Ideally you would engage a landscaper to give you some insight what they may need in the space to make your vision come to life… 1 13593 I ended up going with 'Andrew Belic Construction Co.' https://www.instagram.com/andrewbelicconstruction/ 2 59595 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 10791 |
