Browse Forums Building A New House 1 Apr 02, 2013 12:26 pm Hello All, Well our build is slightly delayed as we made some final structural changes!! Haven't had much luck as the neighbouring block has dumped & compacted heaps of soil containing limestone so have got the council on it. Yesterday when I was at the block I noticed that our little retaining wall (the block next to us is slightly higher by 30cm) has cracks in it from top to bottom. We are building our garage against the retaining wall and just wondered whether anyone has encountered this? Will we be required to fix before construction? If so, do we have a leg to stand on with the developer of the estate because as yet no construction has happened on our block and the neighbouring block to suggest ground movement. Any ideas? Purchased Land: October 2010 Pre Quotation: August 2012 Pre Start Complete: 29 Nov 2012 Refinance for Build approved: 11 March 2013 Due to commence build!!!! It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17202 Do I need to concern about this pattern of crack? Is this crack showing some signs of bigger problems? Thanks for any suggestions! 1 1919 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 5197 |
