Browse Forums Building A New House 1 Mar 25, 2013 12:52 pm I am assuming there has been a thread on this before, but I can not find it for the life of me. I would like to know the permits that are required to build a house (I am in Melbourne, Whitehorse Council), and to find out who generally applies for each of the permits - the owner or the builder? Many thanks Re: Who applies for which Permits? 2Mar 25, 2013 5:12 pm I assume you are asking about building permit. Building permit is applied for by the owner or owner's agent (builder) on behalf of the owner. If the builder is also providing design then it is likely that the builder will apply on your behalf. If you have separate designer from the builder then it is common for the designer to apply on owner's behalf. This is also true if you are applying for a planning permit. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Who applies for which Permits? 3Mar 25, 2013 6:32 pm Other permits are Planning Permit Obtained by developer if buying a subdivision, by you if you are subdividing a block Road opening Permit builder applies Occupancy Permit Builder arranges. Some more information here: http://www.anewhouse.com.au/?p=4822 The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Who applies for which Permits? 6Apr 03, 2013 8:08 pm Planning permits. sometimes the owner, sometimes the builder, and sometimes a consultant. Most of my clients seem capable of doing this themselves. Building permits. I think this is the builder's job. just a view. Occupancy Permits. This is up to whoever it is that applies for the permit. There are a lot of variations on a theme. Have to write a book about it! ask me if you want to know more. Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6348 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7564 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7258 |
