Browse Forums Building A New House 1 Mar 12, 2013 3:48 pm What if I just have a couple of grate drains? Im going frameless/no door etc. Am I correct in my understanding - a reflux valve is simply to stop water coming back the other way in case of a blockage right? Ive never had a shower blockage so - just working out best way to do it. Ive been quoted $1400 to go hobless. Building with 101 Residential in Falcon. Re: Do I need a reflux valve on a hobless shower? 2Mar 12, 2013 6:01 pm Essentially that's the purpose of the reflux valve yes. If the shower is upstairs then you don't need a valve. It's something to do with needing a 150mm minimum allowance (the hob normally) to prevent sewer from spreading through your house. Or something like that. I'd rather pay $1400 than have someone else's sewer run through my house.. Re: Do I need a reflux valve on a hobless shower? 3Mar 12, 2013 6:42 pm Hi there. Thought that I would say a bit about these things. I think they are more trouble than they are worth. If you consider there are moving parts under your slab, that can and in my opinion will foul up at some stage, causing a slow drain at best. I personally would not suggest, or consider the use of these items. One could also ask, if you fit these to the hobless showers, what about the main floor wastes in ground floor bathrooms? Thanks guys Erik Bohl Bathrooms BSA: 67641 ABN: 89 250 897 460 Ph: 0437 528 563 Fax: (07) 5577 2173 bohlbathrooms@ymail.com Good luck with it. I don't know what the cost of a nice bidet seat with a 25mm air gap will be but you are obviously deducting the cost of a RPZ valve and its… 9 6985 First time building 2 storey home, is under construction (in Framing stage) in NSW. I have 3 toilets and need bidet spray in… 0 16853 Ask yourself if the insurance company will be aware of the Reno. 4 7371 |
