Browse Forums Building A New House Re: Did you wet cure your slab? 41Dec 14, 2014 10:26 pm ...most likely the white powder if there is any, ....as the slab dries out will by 'free lime' or 'salts' forming as crystals that will sweep away. and eventually disappear. Sometimes can be refoered to as 'efflorescence'(sp?) The concretors have the change over from winter to summer concrete adds' and the additives used and the weather changes make for 'rapid cure'. during windy and warm dry conditions. What you describe is why we use plastic and sometimes hessian to develop the colour a bit. The blemishes will have character or 'pateenering'. Good luck with the polished concrete. Where you are coming from is where you are going to... Re: Did you wet cure your slab? 42Feb 11, 2015 12:25 pm Plastic does a heap better job Where you are coming from is where you are going to... Re: Did you wet cure your slab? 43Feb 11, 2015 3:39 pm Hi, So I appreciate this is mainly aimed at OBs but what questions should we be asking our project builder with regard to curing slabs? I read on a similar thread about the slab needing to be perfect if laying vinyl planks (which we are) so I want to do what I can to make sure it is. If it falls to us, watering is not a problem as OH is a water carrier. The slab is due to be laid in the next month or so in WA. Thanks! Re: Did you wet cure your slab? 44Feb 11, 2015 8:09 pm Anything that I might add to a thread is of my personal and trade experience. How you use it is up to you. .... .... Ask the builder to look in the right hand side (or possibly the left, depending on which state or territory of the country you are in) for the slab and footing detail. You will find: Provide an approved method of cure for a minimum period of 7 days. disclaimer: Look in all corners that mention slab, slab and footing details, engineering plans, site plans or something that describes the requirements of the engineer to portray to the builder the slab is to be cured using a waterproof membrane or other approved concrete curing agent. It is there Then just ask for plastic ..... ..... Where you are coming from is where you are going to... All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3789 Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40466 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11779 |
