Browse Forums Building A New House 1 Mar 10, 2013 1:31 pm Hi guys, I am building a new home in Craigieburn. My builders told me that my land has 1.82 fall. Roughly it is 223.45 on back left, 223.52 on back right, 225.25 on front left and 225.25 on front right. They also advised that I should be expecting higher site costs. But my concern is, apart from high site costs, is it safe to build on this much fall? Will there be any issues with the house performance in long term? And also, if I am expecting higher site costs, how much I should be looking at? I am brand new to the market and trying to get the answers on my own before I can negotiate with the builders. Your advise will be highly appreciated on this one. Thanks Re: 1.82 Fall on land 2Mar 10, 2013 2:15 pm Hi Gauravarora, How big/long is your block? Safety really shouldn't be of any concern as the engineers will need to design a slab which the builder will build and the building surveyor will need to inspect & sign off. My house has about 1.6m front front to rear and the site costs are about $50k on top of a standard S class flat block. I've gone to a number of builders and they all charge something similar to this. Hope I've helped. MV Re: 1.82 Fall on land 3Mar 10, 2013 2:20 pm Hi MV, Thanks for the response. My land size is 12.5 x 32 (400 Sq meter). What impact will it have on site costs (I am assuming smaller the land size, lower the site costs are).. Re: 1.82 Fall on land 4Mar 11, 2013 10:50 am Is that fall over the entire block or over the building pad? If it is over the whole block, it's not too bad. Over the building pad, I'd be looking at a split level design. Have a look at my build thread. I have about 5m fall front to back over 50m. I can't comment on additional site costs as mine is always all fixed price however doing split level will be more expensive. Re: 1.82 Fall on land 5Mar 11, 2013 4:35 pm With that much slope, it may in fact be more economical to work with the slope - split-level - than against it with retaining walls and fill. Depends on how much of the slope is where; my block is 16x32 with a total fall of about 2-2.1m. But only 1.2m is over the building envelope and the estimate for extra site costs is being quoted at about $20,000. They claim that is conservative but in my rough budget, I'm allowing $30,000. Can't get more precise until the developer finishes his earthworks and the actual final slope can be checked rather than the developer's currently intended result. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: 1.82 Fall on land 6Mar 11, 2013 7:59 pm Hi, will cost around 30-40k have done a few like this in doreen, nothing to stress about for future issues, just make sure they put a good agi drain in with a few plastic pits, having such a cut you will be flooded if you dont have a good drain. have seen this happen manny times. Rama. Re: 1.82 Fall on land 7Mar 11, 2013 8:16 pm Thank you all for your replies. really appreciate your responses. I am not very sure about the fall that is it on entire block or just the building pad. But now I have some idea how to talk to my builder. I'll stay in touch with my builder in coming weeks and will keep you guys posted. Thanks once again. Thank you Splashers. Tomorrow I might check if I can get a few packs of 300x300 in the same tile finish. It may be good to use these could in the shower recesses. I'm not… 4 4684 I've got a challenge here. Background is the builder has cut too deep for the slab and the slab is now below the very substantial retaining wall. It's failed occupancy… 0 18394 AS4654.2-2012 External Membranes it is "Informative" but if you get water ingress your insurance assessor will go to this straight away and if not achieved, they will deny… 9 1880 |
