Browse Forums Building A New House 1 Feb 19, 2013 11:49 am Hey all we are in the finishing stages of our house in lalor. Unfortunately yarra water decided to put the front tap and water meter directly in line with our front door. Has anyone had to move this before? i called yarra valley water and they said we could move it up to 500mm using a licensed plumber. If more than that we need to pay for the water to get cut off, capped and moved and that could cost thousands. Any good plumbers in the north? 2 Re: Moving water meter 2Feb 21, 2013 7:16 pm Unfortunately this is the case, We had (Still do) our water meter installed in front of our door. The cost to move it and the need to mess around with paper work from our water authority proved to much hassle to go down that road. Luckily for us we were able to build up a garden bed around it, and our landscaping company removed the tap and installed the irrigation where the tap used to be. So now its just the meter there and it really does not stick up that high. This also meant the tap was moved to another location for less than it would have been to move on its own. Hi trushan sorry late reply. We just filled a form online requesting water SA to move our water meter. That includes paying right away depending on the distance or how… 2 1494 Hi, I am owner building and need to move our water meter. It is currently right in the middle of our stairs to our front door and is a 20mm inlet. I believe in Victoria… 0 9127 A sparkie might have a stronger view. Try posting the same Q in the Whirlpool Forums Home lounge, there are lots of sparkies on there. To uplload a photo on WP, you need… 5 1333 ![]() |
