Browse Forums Building A New House 1 Feb 18, 2013 12:00 pm We have our colour selection next Monday, and because this house is already sitting 100K over budget (without soil testing and upgrades) we are trying to look where we should try and save. I would like to know what are the things that we shouldn't try and scrimp on, but things MUST be done at the building stage as they are impossible, too hard or too expensive to try and do later??? If it helps we are building double storey (plans are in the sig) Re: Where to try and save??? 2Feb 18, 2013 7:27 pm Definitively need to get down lights on the lower storey at build. Air con also a must in a double storey at build. Water tap behind fridge if you wish to have a fridge with that function. Measure your fridge plus a fridge that you may purchase in the future to make sure it will fit. If you are having Niches in the shower they must get down on the build due to water proofing etc... If I can think of anything else I will add to this. Built a Hawthorne 31 with EB nessjeffdreamhouse.blogspot.com.au Building an investment now with New Living homes... We are at nearly finished... Just landscaping and driveway to go! Re: Where to try and save??? 3Feb 18, 2013 10:15 pm Roof sarking - From what I know it has to be put under the roof tiles/colorbond roof just prior to the roof tiles/colorbond going on and can't be done after... correct me if I'm wrong! I've just had a look at the website. The company are just building broker's. There are plenty of similar companies that basically draw your plans (they own them so you… 8 10929 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10041 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6178 |
