Browse Forums Building A New House 1 Feb 16, 2013 7:54 pm Building our first house and we are doing final alterations to structual tomorrow. Undecided on living/dining area window configuration. Original has 2x2510 windows. My idea shows 2x1210 and 1x1710. Giving two walls between the three windows of approx 2000mm length, so as to leave the option of where we have the family area closer to alfresco or closer to garage. Any draw backs of my idea as a potential buyer buying my house in say 5 or 10 years. Im not sure what people look for when buying. original.... http://s1326.beta.photobucket.com/user/ ... sort=3&o=0 My idea.... http://s1326.beta.photobucket.com/user/ ... sort=3&o=1 Re: Quick advice needed on window configuration of living ar 3Feb 16, 2013 8:49 pm I would go for the 2 windows which give more window area. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Quick advice needed on window configuration of living ar 4Feb 16, 2013 11:28 pm My problem with the smaller windows is that I would want to put furniture against the end wall that's shared with the garage - bookshelves at the least - and having the window too close to the corner makes that harder. It also makes window coverings more complicated. So keep windows at least 400mm from the internal corner (in my opinion). Also related to that is using the wall space between windows. Think about people putting things like a buffet/sideboard there; will it fit? Where else could you put it? Design the windows around maximising furniture placement flexibility and light/solar optimisation; you don't say which direction that wall faces and that would affect my choice. If it is facing west particularly, then shrink the windows! If it is north, think about how you will shelter them in summer and not in winter (eaves, pergola, etc.). Have fun. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Quick advice needed on window configuration of living ar 5Feb 17, 2013 11:44 am The way I see it is have furniture running along the garage wall and with the windows not being floor to ceiling there would be room for a table under the window. THe living side will be facing north and the alfresco will be facing west. So the whole floor plan there needs to be flipped. Re: Quick advice needed on window configuration of living ar 6Feb 17, 2013 12:22 pm 2 looks better. Looks like you'll be sitting in either room looking at wall instead of window if you have three. Re: Quick advice needed on window configuration of living ar 7Feb 17, 2013 1:27 pm 2 x big windows and I agree with CamErin, use 16c or 14C windows so it maximises your avilable wall space, as oppose to 25c windows. 3 5595 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16565 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 8327 |
