Browse Forums Building A New House Re: Building Aspiration 35 Wisdom Homes at the Ponds 221Jan 21, 2014 1:13 pm That's good then. I really want to walk in with internet so hopefully i can book in at my lockup stage. Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Aspiration 35 Wisdom Homes at the Ponds 222Jan 21, 2014 8:57 pm Hi cspaces saw earlier in the blog, you were getting a quote from betterview blinds for flyscreens, is that cheaper, than wisdom charging $40 per fly screen. Do you have an idea on the cost of plantation shutters with them. We are @ the tender stage. about to put down the 3K for the next step to get the plans drawn, trying to get the most accurate tender possible. Does wisdom do solar panels or best to do that after the completion of the house. thanks Re: Building Aspiration 35 Wisdom Homes at the Ponds 224Jan 21, 2014 9:50 pm Hi ugly99, Wisdom outsource the flyscreens to Betterview which explain why my quote with flyscreens are exactly the same. $40 a piece regardless size. We're not using Plantation shutters. I would suggest to add them into the tender quote. I'd suggest to add anything you'd like to know into the tender stage. Deleting item from the tender is a lot easier than adding them in. Add allowance for kitchen upgrade, electrical upgrade, landacapes. These allowance should give enough real value in case you're getting a finance from bank. And also home owner insurance only covers the value of the original contract value which based from original tender, not including post contract variation. I've learnt this too a bit late. I'm planning to do solar later after handover. There are lots of good deal out there. Although I heard from a friend that if the external solar installer made a 'boo boo' with the roof, WH will not going to cover if anything wrong happen on the roof. Again this may be just a speculation. You can decide yourself. The reason we choose roof tiles was because we like the range. I heard that colorbond roof maybe loud during heavy rain. It also seems more durable than tiles. So are you still going ahead with Impression design? Re: Building Aspiration 35 Wisdom Homes at the Ponds 225Jan 22, 2014 12:03 am Hi cspace, thanks for the answer, I will check with wisdom re plantation shutters to see the cost. electrical upgrade I added $8.5K I saw your blog and electrical plan so I used it to figure the extra powerpoints/network points required. They are giving us 9K landscape voucher, do we need to allow for more? Kitchen upgrade, as part of prestige package we got 40mm benchtops, DW, prefers polyurethane doors not laminex so may need to add that. any other gotchas, yes we are going ahead with a impression 37 with some mods. Re: Building Aspiration 35 Wisdom Homes at the Ponds 227Jan 22, 2014 10:32 am I'm glad my electrical plan helps you. I wish more and more people share their electrical plan. During my research on electrical plan, I only found a few plans that useful to me. Even on my plan I missed several things like more powerpoints in some corners, more junction boxes etc. $9K landscape voucher?? That's very good. I only got $5.5K. Landscaping is one big spending too in building a house. I've read that 10% of the value of the house is a good ballpark figure for a standard landscape. Just a driveway would cost you $5k-$8k. Not to mention if you need to fill in some soil for a level backyard, retaining walls and plants. We spent quite a bit for kitchen because we totally change the kitchen layout from the original design. Forgot to mention about allowance for tiling and flooring. You probably want to upgrade some tiles, feature tiles, better carpet and better underlays. Are you getting the optional Lanai and alfresco? I was considering that plan too. What kind of modification to the plan? Good luck with your tender. Hope to see some pictures during the build. Re: Building Aspiration 35 Wisdom Homes at the Ponds 228Jan 22, 2014 2:12 pm Hey cpaces I am getting a quote from Beterview as well. Hope they give me good price!!! Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Aspiration 35 Wisdom Homes at the Ponds 229Jan 22, 2014 3:07 pm Yes we got the lanai and alfresco and added another room to the rear next 2 the alfresco. Do you need 2 add the upgrades to the tender re carpet/tiles or u deal with dilorenzo directly? We want 2 upgrade the stairs from carpet 2 floorboards not sure anyone has done that or costing would be great Lots of reading 2 do still thanks for tips so far. You terminated your n/w in the garage u are putting a rack and switch there 2 any cooling planned Re: Building Aspiration 35 Wisdom Homes at the Ponds 230Jan 23, 2014 11:21 am @Transformation. I'm sure you will have good experience with BetterView. We have one of the best experience with BetterView, quick communication, not pushy during the meeting on site and the quote was within the budget if not cheaper. @ugly99 I'd suggest to add allowance into the tender although in the end after the appointment with dilorenzo say you decide to do the flooring yourself then at least the original tender already have the allowance for flooring which should help in terms of Home Owner Insurance figure and Bank finances. I didn't know about any of this too. I also found out that you can have appointment with stairs company who build the stairs for WH. We didn't get inform about this choice at all. You can choose any style you like albeit with extra cost. Onewheel upgraded their stairs if you want some reference. I didn't upgrade the stairs at all since we don't know we had the option. Apparently that's the termination points if you requested WH to install network points. So I was thinking of getting a network rack but now I'd probably re-think or maybe using the IKEA LackRack idea http://wiki.eth0.nl/index.php/LackRack Re: Building Aspiration 35 Wisdom Homes at the Ponds 232Jan 23, 2014 12:57 pm cpaces @Transformation. I'm sure you will have good experience with BetterView. We have one of the best experience with BetterView, quick communication, not pushy during the meeting on site and the quote was within the budget if not cheaper. @ugly99 I'd suggest to add allowance into the tender although in the end after the appointment with dilorenzo say you decide to do the flooring yourself then at least the original tender already have the allowance for flooring which should help in terms of Home Owner Insurance figure and Bank finances. I didn't know about any of this too. I also found out that you can have appointment with stairs company who build the stairs for WH. We didn't get inform about this choice at all. You can choose any style you like albeit with extra cost. Onewheel upgraded their stairs if you want some reference. I didn't upgrade the stairs at all since we don't know we had the option. Apparently that's the termination points if you requested WH to install network points. So I was thinking of getting a network rack but now I'd probably re-think or maybe using the IKEA LackRack idea http://wiki.eth0.nl/index.php/LackRack Thanks cpaces that's what I like to hear!!! I will let you know how I go. On a separate note, my roof tilling started today Find Out About Bungarribee Community At http://bungarribee.com Building Washington 29 from Wisdom Homes - viewtopic.php?f=31&t=63920&p=1011725#p1011725 Re: Building Aspiration 35 Wisdom Homes at the Ponds 233Jan 23, 2014 1:15 pm Thanks MR2. The Wisdom Upgrade Cost thread is here for anyone's looking viewtopic.php?f=31&t=62519 There's something we'd like to share, specially for user darali who brought up the topic to us. We found out that it is important to know your landscape design and the position of the house/slab level early during the landscape design planning especially if you build on a corner lot like us. We also found out the important of this quite recently when we have to fill in quite a lot of soil to make our backyard in nice and level condition. This requires two sets of retaining wall because ThePonds requirements only allows max 600mm high retaining wall. If the slab/house level was placed lower, we would not need the second retaining wall. One retaining wall costs us close to $10K. So our solution at the moment is to use one single retaining wall but let the backyard a bit of a slope. We're a bit lucky that we can have a bit of a slope but just in case that your situation may be different. Anyway, you have to have an opportunity to liaise with a landscape designer, either via WH landscape or external contact, to come up with landscape plan to be submitted to the council for a DA approval. It might be useful to check with the landscape designer the best way for the slab to sit in a particular level with your choice of landscape design. I think you have to worry about this right after you have the first drawing after they survey the land. Then when you gave the drawing to the landscape designer you can worry and ask if you need a retaining wall and probably adjust the proposed slab level to be adjusted with the landscape design so you have a nice and level backyard. On other note. We've heard from Wisdom Landscape today that our driveway can be installed in about 1.5 week. This is great. That means we're very close with our handover. Re: Building Aspiration 35 Wisdom Homes at the Ponds 234Jan 26, 2014 11:01 pm Hi Cspaces, Thanks for the information. Q re painting does wisdom allow feature walls( different colour on a wall) in each room, or is that extra cost. The hills alarm has anyone upgraded it to extra sensors what is standard? We have standard the 2340x1200 door it has clear glass, has anyone upgraded to translucent glass to not be able to see in. Keen on adding a security door 2 @ the front, and flyscreens/security door the stacker @ the rear, does betterview quote and can be installed before handover? thanks ugly99 Re: Building Aspiration 35 Wisdom Homes at the Ponds 236Jan 28, 2014 8:56 am Yes. Featured wall painting is extra cost. I think standard wall costs $300. We only asked for the stairs wall since its harder to do ourselves. It costs $600. We just use the standard alarm with standard sensors. We've added a translucent glass for the front door. Extra $120. You can do it yourself post handover but from my friend who did it recommended us to spend it with the builder. Neat and a lot cleaner than do it yourself. Since Betterview price is the same as with WH if you put them together in the same tender then they can be installed before handover. Having said that Betterview is WH primary supplier so they have access to your house plan and builder masterkey. It's a lot easier to measure and quote. One downside is to keep their costs down, they do not have shop front for you to see. They will come to you to show their samples. I've never meet my SS up to this point however 90% of the time he calls us every Friday with update on what's going on and what's next to be done. We're blessed to have such an amazing SS. Flexible yet get the things done quickly. In a few weeks we'll be seeing him face to face for the first time during PCI. Every SS is different according to stories in this forum. Have you sign your tender yet? Re: Building Aspiration 35 Wisdom Homes at the Ponds 237Jan 28, 2014 12:20 pm Happy Australia Day everyone. Just a bit of an update for our build. Over the weekend we were advised on the date for informal walkthrough. The date is Fri, 14 Feb 2014. SS didn't mention the term PCI, he only mentioned informal walkthrough. Go figure. At least nearly finished. We also decided to get an independent inspection organised before then as they would know what to inspect that we'd probably missed. We are very happy with the work from Wisdom Homes so far. Some pics: Stove exhaust Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ powerpoint and network point underneath the kitchen island Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Front piers in moroka finally painted Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Linen shelf installed Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Designer Front Door handle Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kitchen Splash Back in Antique-White Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We were thinking or adding a timber slats divider near our living area. I was researching on this and not many information in this forum. Does anyone know anything about this? Does any carpenter able to create this sort of divider? This is the picture that we're thinking of. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building Aspiration 35 Wisdom Homes at the Ponds 239Jan 28, 2014 1:09 pm Really nice! I love your walls, kitchen, everything!!! Re: Building Aspiration 35 Wisdom Homes at the Ponds 240Jan 28, 2014 2:03 pm Hi cpaces We will be building Manhattan and we are closing to signing the contract. I don't know if you have see the display home at Kellyville, they have something very similar which divided the living and the rumpus rooms which we are getting. It is an upgrade and I can send you the cost if you need them. Your kitchen looks very nice!!! Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 18628 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 73681 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 8602 |
