Browse Forums Building A New House 1 Jan 31, 2013 3:00 pm Hi, Would love to get some ideas/inspiration from anyone who has built on a downwards sloping block (as in, slopes down from the road). Our land drops down about 5m from the road, and about 3-3.5 across the building area. Hungry for any ideas/pics/links that others have found useful. Cheers Re: post your down-slope house builds- split level,tri-level 2Jan 31, 2013 3:16 pm Hi Conrad, My build has a similar downward slope (however not so bad across the block). Check out the link in my sig. Splits are fun to build - bit more interesting than boring flat houses. Re: post your down-slope house builds- split level,tri-level 3Jan 31, 2013 5:06 pm Wow! Atom that is an amazing house you are going to have there mate! Some great ideas that echo my own thoughts, plus plenty of new ones to ponder... you are definitely right about splits! I'm in QLD too (building at Upper Coomera, Gold Coast) sadly it seems like the southern states have more project home builders with off the shelf plans as so many just want to do a massive cut and fill if they want to build on it at all. To me that is pointless- sinking money into site costs to build a flat house, which could have been built more cheaply if I had a flat block to start with. Might as well use the slope to make the house more interesting. I actually had a builder say to me the other day "The problem with split levels that most people don't understand is that it means there is STEPS inside the house!" .... I replied with stunned silence, and got off the phone fairly quickly afterwards... I wanted to say "Really??! I thought I could use an elevator!" haha. Re: post your down-slope house builds- split level,tri-level 4Jan 31, 2013 6:15 pm We are building on a down sloping block. The block drops 9m over the entire length (50m). See the links in my signature for further info. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: post your down-slope house builds- split level,tri-level 5Jan 31, 2013 6:44 pm Konrad I actually had a builder say to me the other day "The problem with split levels that most people don't understand is that it means there is STEPS inside the house!" .... I replied with stunned silence, and got off the phone fairly quickly afterwards... I wanted to say "Really??! I thought I could use an elevator!" haha. Hee. I was looking at one very sloping block a few months back and pondering custom house designs and I was actually thinking about using a ramp instead of stairs. It could have been amazing... just expensive. I have a down slope on my block. It is 0.8m over the 4m front setback, then 1.25m diagonally over the rest. Back boundary is a 1.2m high retaining wall; I'm on the high side. It's enough to up the site costs, I'll just have to wait and see by how much. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: post your down-slope house builds- split level,tri-level 6Jan 31, 2013 8:11 pm we talked to ezy homes in qld about building a skillion roof modern house (not what we wanted but the only option for the block which was cheap and big) on a 1 in 5 grade (1m drop in 5m) they were very helpful but the block sold so we decided to build the house we really wanted on a not so steep 1 in 7 just around the corner, 70k more for the block, our current one is on my build thread, I can upload to photobucket tomorro the skillion ones or email to you, cheers Russ... Re: post your down-slope house builds- split level,tri-level 7Jan 31, 2013 8:29 pm Konrad Hi, Would love to get some ideas/inspiration from anyone who has built on a downwards sloping block (as in, slopes down from the road). Our land drops down about 5m from the road, and about 3-3.5 across the building area. Hungry for any ideas/pics/links that others have found useful. Cheers Sounds like the almost the same land as mine. Checkout my thread for ideas. Build Thread: viewtopic.php?f=31&t=57639 Re: post your down-slope house builds- split level,tri-level 8Feb 01, 2013 9:34 pm hi konrad! im currently building a split/tri level on a 36m metre block with a 2.8m fall from front to back. check out my thread for info and pics viewtopic.php?f=31&t=57505 Timeline Land deposit 14.9.10 Land settled 16.6.11 DA submitted 13.3.12 DA appoved 17.5.12 Construction cert 6.7.12 Site scrape 23.7.12 Lock up 29.11.12 Re: post your down-slope house builds- split level,tri-level 9Feb 02, 2013 11:40 am Thanks everyone.. HomeAngels, plucka and Em.Russ you are going to have amazing homes. Lots of good ideas in those plans. Plucka it seems like you are building with Steve Parcell? Is yours a custom design or do they have an off shelf plan to modify? Thanks rusty for the heads up on ezy homes. Weren't really thinking kit homes but will now look into it more. Re: post your down-slope house builds- split level,tri-level 10Feb 02, 2013 1:07 pm Konrad Plucka it seems like you are building with Steve Parcell? Is yours a custom design or do they have an off shelf plan to modify? Yeah Steve Parcell. My original plan was copied from another build they did on a similar slope which I then modified to my liking. Worked out very well in the end. Build Thread: viewtopic.php?f=31&t=57639 Re: post your down-slope house builds- split level,tri-level 11Feb 02, 2013 2:21 pm http://forum.homeone.com.au/viewtopic.php?f=31&t=58348 Another build that fits the question: Re: post your down-slope house builds- split level,tri-level 12Feb 09, 2013 1:50 am ezi homes can build to any stage from memory, depending on where you live Re: post your down-slope house builds- split level,tri-level 13Feb 09, 2013 10:19 am Here's what we're doing, but we only have the downwards slope and no sideway slope. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My Hamptons build (completed): viewtopic.php?f=31&t=63370 Moved in Wednesday 11th Dec 2013 Front landscaping completed June 2016 Re: post your down-slope house builds- split level,tri-level 14Mar 19, 2013 6:09 pm Our block falls by 5m over the length of the building envelope and then about another 5-7m down to the back of the block. We approached the problem by digging down and making the back of the house double storey and the "top" level able to be entered at street level. This has worked well for us as the garage is still under the house which suits our needs and the main living areas and deck are on the top level overlooking at the back and west side of the house. These areas look down the hill and have a great view that can't be built out and the breeze and light in the rooms on hot days is great. We specifically chose not to go split level as we want to live in the house when we are ancient and did not want to have to go up and down stairs numerous times a day when we are old. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: post your down-slope house builds- split level,tri-level 15Sep 02, 2013 3:06 pm plucka Konrad Plucka it seems like you are building with Steve Parcell? Is yours a custom design or do they have an off shelf plan to modify? Yeah Steve Parcell. My original plan was copied from another build they did on a similar slope which I then modified to my liking. Worked out very well in the end. Hi Plucka, How is your experience with Steve Parcell? they are on our short-list currently. We are building in Rochedale. Thanks, Jellofish Move your linen into laundry and access laundry from your present linen space 1 8007 Hi, We are looking for a builder that can build a small home (smaller length) on a sloping site. We came across Mojo's Zephyr design 10.6 m wide and 11.5 m length. Does… 0 23014 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 223604 |
