Browse Forums Building A New House 1 Jan 29, 2013 5:28 pm Hi there, We are building our first home, a double storey home (12m wide*16m deep) on a 16m*40m block. In our design we have an option to add a theatre in the place of garage, but then we have to push the garage to the front wall of the house. This means garage will look like an attachment on the front right hand side corner of the house. We have seen some old house of this style, but not many new ones. Does this house look good aesthetically? If we get a theatre (3.5m*6m) by sacrificing the look, is that a worth decision? PS - I was trying to attach the plan here, but I cant upload the photo in to this box. Could someone tell me how to paste a photo here - that would give a better picture than what I described above. Thanks in advance for your comments. Re: Is pushing garage towards the front a good idea? 2Jan 29, 2013 5:42 pm I've seen quite a few designs like this; it's not completely unusual! Only problem is that, most likely, it will push your entire house backwards on the block. Most councils (and CDC in NSW) require a minimum distance from the street, most commonly that is about 6m, and if your garage is in front of the house then the rest of the house is therefore pushed backwards. So have a look at how much back-yard you want; pushing the whole house backwards might reduce the backyard more than you want, but maybe it won't. If you don't like the back yard being reduced so much, is it posaible to have the media-room out the back where it only reduces one side of the yard? Also check with the council (if not in NSW & building under CDC), I thik in some areas the garage is allowed to be closer to the road than the house is allowed to be. Re: Is pushing garage towards the front a good idea? 3Jan 29, 2013 5:53 pm Thanks Forg, I will be getting a 13m deep*16m wide backyard which I think should be enough for the kids to play around and do some outdoor entertaining! We are VIC and the minimum setback is 5m. Re: Is pushing garage towards the front a good idea? 4Jan 29, 2013 10:58 pm Our estate/council guidelines were a 4m minimum setback to the front of the house but 7m minimum setback to the garage. Might be worth checking if this applies to you because you would then need to push the entire house back as Forg said. Re: Is pushing garage towards the front a good idea? 5Jan 30, 2013 7:36 am I've seem a few homes in our area with the garage at the front and they look OK. But i guess you want as much backyard as possible? If you put the garage at the front, moved forward due to home theatre, you most likely have to move the whole house back to meet council set back rules and lose some length of your backyard and the full width across. But if you add the home theatre at the back of your house, you would lose only a portion of your backyard, only the length and width of the home theatre, assuming it would not be the whole width of the house. I guess draw up your house with both options on copies of your block plan. visualising both examples on the block plan might help the decision process. We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Is pushing garage towards the front a good idea? 6Jan 30, 2013 7:41 am If you mean the garage is "tacked-on" to the side then why not have an outside area on top of it. Would look great and give the house a good "look" too. Re: Is pushing garage towards the front a good idea? 7Jan 30, 2013 8:30 am Onewheel I've seem a few homes in our area with the garage at the front and they look OK. But i guess you want as much backyard as possible? If you put the garage at the front, moved forward due to home theatre, you most likely have to move the whole house back to meet council set back rules and lose some length of your backyard and the full width across. But if you add the home theatre at the back of your house, you would lose only a portion of your backyard, only the length and width of the home theatre, assuming it would not be the whole width of the house. Hmmm, some interesting points you make there ... Re: Is pushing garage towards the front a good idea? 8Jan 30, 2013 4:16 pm Hey Forg, just realised I've basically said the same as you, lol. Sorry! We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Is pushing garage towards the front a good idea? 9Jan 30, 2013 4:43 pm Hey can anyone clarify the nsw legislation regarding the garage thing? It says 5.5m setback AND 1m behind the 'building line'. Is the building line where your house starts or where the boundary line is? ATM I have it set back from the front of the house by 1m but if it can be flush with the front of the house then I can have a bigger bathroom window for more light. Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Is pushing garage towards the front a good idea? 10Jan 30, 2013 6:57 pm I would have thought it means 1m from the front line of the house. Our estate rules are the garage 840mm behind the front wall of the house. Why such a weird figure I don't know but we put ours around 1800mm to have a longer driveway. You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4859 Get some long brass machine screws and bolt right through the gate and put brass acorn nuts and washers on the other side. It will never come off 1 9080 that will depend on the kitchen bench depth. you'll have to specify it so it allows for both the tap and the sink 1 7398 |
