Browse Forums Building A New House 1 Jan 27, 2013 8:39 am Many people still don't understand why you should have pre plaster inspection or whether it is worth spending around $500 to have one. Even our building control system does not require one and I think it's criminal negligence from our regulators because it allows framing defects and defective fire separation walls (in units) to be covered up. Here are my reasons: 1 A chance to verify that any framing defects discovered during framing inspection have been adequately addressed. 2 To verify that no building elements have been damaged by other trades, I often find damaged bracing and hacked beams. 3 To ensure walls have been straightened properly 4 To verify services rough in 5 To verify wet areas preparations There is a lot to look at and many things can go wrong and unless you are trained and experienced to spot defects there is a good chance you will miss some. You can see some photos on: http://www.buildingexpert.net.au/blog/p ... our-build/ Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Pre plaster inspection, small things make big difference 2Jan 27, 2013 12:34 pm Completely agree. Its such a small price to pay for such a big investment. I had one done by hkryan in Sydney and the things he found made it so much value. Missing triple grips on trusses. Missing shear blocking. Copper piping not insulated from other metals and a host of other little things. And I thought I had an eagle eye! How will you know its wrong if you dont know whats right. I pays to use a professional. It cetainly saved me headache and money down the track! Masterton Symphony MBTF @ The Ponds 2012 Mar. Commencement May. Plans Jun. Contracts Aug. Selections Sep. DA Oct. Construction Nov. Slab, Frames, Bricks Dec.Roof 2013 Jan. Lockup, Fit out The worst thing you can do is sign a building contract without a pre contract review. Over the years many people have come to me with disputes where they just signed… 0 8340 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2038 Hi, Have used the Dulux 1 step, oil base on my walls(white set), out of can it’s already a more thinner product than a final coat paint Also in water base Water or… 3 5026 |
