Browse Forums Building A New House 1 Jan 25, 2013 11:10 am Without specifics it is hard to answer this, however the way corner lots work normally is that the side which has your vehicular and pedestrian access is considered the primary street. That being said some local authorities do have policies which change this rule. Some will specify specifically which has to be the primary street and which has to be the secondary street the best thing for YOU to do is to get the answer direct. Call the local authority and arrange a meeting with a planner. Take your floor plan and site plan in a discuss it with them. Your argument about northern light is a solid argument, so mention that to the planner. At least then you can be assured of that the issue is without getting second hand information from people who's motivation is to make money off hurrying you through the process. Re: Primary Street Frontages - HELP! 2Jan 25, 2013 5:05 pm We have a corner block as well and experienced the same problems as you describe. We choose not to change the entry, but instead have a custom designed house. Is this an option? How deep and wide is your block? Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2778 Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 7307 Hi there, long-time lurker but first time posting. I've bought a house 2 and a bit years ago and last year we had some major water damage on a converted pergola area… 0 7932 |
