Browse Forums Building A New House 1 Jan 18, 2013 2:46 pm I was just looking at fridges online as we will need one when we move. I double checked our dimensions and the depth of the space for the fridge seems to be to be 600mm. Problem is all the fridges I can find are measuring more than this. Is it normal for the fridge to stick out a little? I can't think for the life of me if they do or not Otherwise I will need to contact the builder to see if this measurement is correct. Cheers Sam Our first home... viewtopic.php?f=31&t=60460 Land Dep paid 26/2/12 Site cleared7/12/12 Slab 20/12/12 Frame 25/1/13 Bricks 19/2/13 Re: Silly question about fridge space 2Jan 18, 2013 3:29 pm spottie I was just looking at fridges online as we will need one when we move. I double checked our dimensions and the depth of the space for the fridge seems to be to be 600mm. Problem is all the fridges I can find are measuring more than this. Is it normal for the fridge to stick out a little? I can't think for the life of me if they do or not Otherwise I will need to contact the builder to see if this measurement is correct. Cheers Sam hi sam yes they do Deposit on land 20/03/12 Deposit with Builder 01/07/12 Tender signing 12/10/12 Into Council 20/01/2013 Site work started 30/04/2013 Keys 15/11/2013 What can i do tomorrow better then today Re: Silly question about fridge space 3Jan 18, 2013 3:32 pm just checked our fridge and yes it is sticking out too Re: Silly question about fridge space 4Jan 18, 2013 4:00 pm They have to sit forward of the space so the doors open Re: Silly question about fridge space 5Jan 18, 2013 6:13 pm fmac They have to sit forward of the space so the doors open This. Ideally, the hinge/seal on the door is about level with the wall or cabinets alongside. Land settled May '14. Building the PD Hoffman39: 5/11=site start, 13/11=slab pour, 26/11=frame complete, 10/12=roof on, 12/12=bricking started. Blog: http://jyndeira.net/blog/ Re: Silly question about fridge space 6Jan 22, 2013 4:33 pm Thanks everyone!!! Our first home... viewtopic.php?f=31&t=60460 Land Dep paid 26/2/12 Site cleared7/12/12 Slab 20/12/12 Frame 25/1/13 Bricks 19/2/13 Re: Silly question about fridge space 8Jan 26, 2013 12:27 am The size includes the width of the door and some even the door handel. best to go out to the shops with a tape measure. have power point moved to not be behind the fridge as that wil eat up 50mm Hurry up and wait Re: Silly question about fridge space 9Jan 26, 2013 2:16 pm Perth Dream The size includes the width of the door and some even the door handel. best to go out to the shops with a tape measure. have power point moved to not be behind the fridge as that wil eat up 50mm True but not really an issue as you also need to leave a bit of a gap around the fridge for air circulation. Jamb your fridge hard against the walls and it will most likely work too hard and burn out much sooner. Build Thread: viewtopic.php?f=31&t=57639 Re: Silly question about fridge space 10Jan 26, 2013 7:05 pm Make sure you ask for the fridge space to be fitted with plumbing for cold water ( depending on where the fridge is located, it can be difficult to add the plumbing later). Lots of fridges have water chillers and ice makers these days. Build thread: here Land Nov 12, Contract 6/07/13, Consent 15/08/13, Start 20/09/13, Slab 25/09/13, Frame 4/10/13, Brick 21/10/13, Roof 2/11/13, Lock-up 17/12/13, Handover 3/3/14 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9979 I had a similar issue with my fridge not too long ago. It wasn't the same model, but the symptoms were pretty much the same: the compressor would start and then stop… 3 7553 Cupcake.girl This really depends on your local council. Each one has different definitions and ways to calculate contributions. This is called a contribution… 1 3588 |
