Browse Forums Building A New House 1 Jan 12, 2013 10:35 pm hey guys, I need your advise. I bought a 600m2 land in Bankstown area for duplex. Just realized I can only get 150m2 living area each after talking with Masterton consultant today. Due to council policy, property living area can not be more than 50% of land size. Is there any way I can build it larger? A strategy passing council or any architect solution? All responses are appreciated. Thanks! Re: anyway I can build a larger duplex? 2Jan 13, 2013 12:02 am jihaomou hey guys, I need your advise. I bought a 600m2 land in Bankstown area for duplex. Just realized I can only get 150m2 living area each after talking with Masterton consultant today. Due to council policy, property living area can not be more than 50% of land size. Is there any way I can build it larger? A strategy passing council or any architect solution? All responses are appreciated. Thanks! Nope, you got no chance on that one which is a good thing imo you really don't want to develop areas that look like slums. Masterton are correct on this one, council will not allow dwellings > than 50% of the land area it changes after 750 sqm, for anything over 750sqm you have 50% on the first 750 and I think it is 25% on the rest above 750. Edit: I'll correct myself it is 50% on the first 700sq and 20% on the rest, you can have a look at the regulations on page 15 and 16 here: http://online.bankstown.nsw.gov.au/Docs/Temp/PgdRRoMSiVxozXGXYgJD.doc_010728.pdf your only hope is if you are developing in an area zoned as 2B. where about in bankstown are you intending to build? Re: anyway I can build a larger duplex? 4Jan 13, 2013 2:16 pm jihaomou thanks PHunter. my land is at Panania. things is I saw some other duplexs in this area are obvious bigger than 50%. how can it be? there was a time when such rules were not in place, i remember seeing a strata construction where you could build 3 seperate houses on a block <1200 now you need >1200 rules unfortunately change and in such situation i think it is better for the area. Maybe not for the builder as they're trying to cash in but for the community. Re: anyway I can build a larger duplex? 5Jan 13, 2013 3:31 pm Is it double story? Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Re: anyway I can build a larger duplex? 8Jan 13, 2013 9:20 pm PHunter jihaomou thanks PHunter. my land is at Panania. things is I saw some other duplexs in this area are obvious bigger than 50%. how can it be? there was a time when such rules were not in place, i remember seeing a strata construction where you could build 3 seperate houses on a block <1200 now you need >1200 rules unfortunately change and in such situation i think it is better for the area. Maybe not for the builder as they're trying to cash in but for the community. Thank you for all the professional advises. You are the expert! Just to clarify, I'm not a builder I've read my own council's LEP numerous times and worked with an architect to understand my own lot size and problems. 5 1818 If so what were the "special circumstances" under which it was granted? "Note: If the development consent is for 'dual occupancy' an owner-builder permit can only be… 0 14070 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11035 |
