Browse Forums Building A New House 1 Jan 11, 2013 10:24 pm Hey guys, Tried to find this info on the forum but couldnt find much relating to it. The house I am wanting to build is just under 60% site coverage, I am allowed 60% in my estate. The house is roughly 13m x 24m single storey. This measurement doesn't include 600mm eaves My question is do they include eaves into the total building size? With the eaves would workout to be another 4% or approx 39msq Problem I'm facing is I love the block and the house design equally Cheers Never argue with an idiot. They will only bring you down to their level and beat you with experience. George Carlin Re: Eaves and Building site coverage 2Jan 11, 2013 10:28 pm ...do they include eaves into the total building size? - Yep. Total coverage is "Proportion of total site area covered by all buildings and structures roofed with impervious materials" i.e. total roofed area including eaves. If it is over, ask for relaxation or if there is an alfresco area you could consider dropping back the size of that area so you slide in on the 60% and add a 'pergola' that can be roofed later. Good luck with it. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Eaves and Building site coverage 3Jan 11, 2013 10:38 pm Someone just PM me a link to http://www.dpcd.vic.gov.au/__data/asset ... VPP_PN.doc It says eaves don't count? The site area covered by buildings should not exceed: • The maximum site coverage specified in the schedule to the zone, or • If no maximum site coverage is specified in the schedule to the zone, 60 per cent. Applying the standard The definition of a building includes a dwelling, a garage or carport, a verandah and any other roofed building such as a garden shed. When calculating site coverage, if the upper storey projects over the ground floor, that part of the upper storey is also added onto the ground floor area. Outdoor paving, driveways, footpaths or building eaves are not included when calculating the amount of site coverage. Never argue with an idiot. They will only bring you down to their level and beat you with experience. George Carlin Re: Eaves and Building site coverage 4Jan 12, 2013 6:12 am I think they may allow some leniency with eaves encroachment - depending on where and how. There are some odd rules with what is and isn't included IMO - eg a pergola, the Alfresco, a shed, etc. Re: Eaves and Building site coverage 5Jan 12, 2013 7:39 am Different states and councils have different definitions. Stating where you are building would probably help. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Eaves and Building site coverage 7Jan 12, 2013 2:29 pm surfprado Sorry guys the property is in Torquay, Victoria No worries. My info was for Brisbane, but interestingly eaves aren't included for homes on blocks under 450m2.... ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Eaves and Building site coverage 8Jan 12, 2013 6:25 pm The 60% is based on the slab area - so the "non-permeable" ground area. Take your m2 of house size - divide it by your land m2 x 100 = your site coverage % Sleven Moved into our Atlantique MkII 36 by Carlisle Homes It looks like Blacktown council allows up to a 6.0m wide driveway so just ask your builder to change the plans. If you are just in the planning stage then there is no… 6 3892 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 8124 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5926 |
