Hello Friends,
I take it that most, if not all of us are building Brick Veneer Homes. Given the costs envolved I would like to know what can be the expected life of such a home. Also would full brick construction homes last longer ?
lobo
Browse Forums Building A New House 1 Apr 13, 2008 1:31 am Hello Friends,
I take it that most, if not all of us are building Brick Veneer Homes. Given the costs envolved I would like to know what can be the expected life of such a home. Also would full brick construction homes last longer ? lobo Buildling a Clarendon Crestmead in Sydney DA Approved on 20/03/2008 Slab Poured on 02/09/2008 Frame Completed 15/10/2008 Brickwork Complete 2/02/2009 Roofwork Complete 05/03/2009 Re: Expected Life of a Brick Veneer Home 2Apr 13, 2008 2:27 am I think that I heard that the average house lasts 40 years before it's torn down and somethign new is rebuilt. I would think that afull brick house would age less quickly and survive longer. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Expected Life of a Brick Veneer Home 3Apr 13, 2008 9:52 am Many older houses here are older than 40 years.
Old stone and solid brick houses. On floorboard bases too, not concrete. Our own house was built in 1959 (double brick, except extension done in 2000 is brick venneer) and stilll going strong! Our new house will be brick venneer because that's all that gets built now, almost impossible in SA to get double brick house now, certainly not a standard home by a standard builder. Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 5494 2 6865 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 3375 |
