Browse Forums Building A New House 1 Jan 08, 2013 10:18 pm Hi, I am going to install a slave air-con controller pannel in my Master Room. But it's difficult to decide which location is the best. There are 4 locations on the cavity wall as options. Anyone can help to give some advises. The Master air-con is in the living area so we don't want to walk there each time. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Uploaded with ImageShack.us Re: Slave air-con controller pannel 3Jan 09, 2013 7:19 am What is the location of the vent? Ideally the controller, if it's temperature sensing which not all slaves are, would not be in direct breeze of the vent outlet and not on an external wall. Also not in direct sunlight. Based on that I'd say below your #4, on the wall shared with the robe. How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
