Browse Forums Building A New House 1 Dec 31, 2012 11:00 am Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Help please! About to embark on building and would advic 3Dec 31, 2012 2:20 pm Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Help please! About to embark on building and would advic 4Dec 31, 2012 4:38 pm Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Help please! About to embark on building and would advic 5Jan 01, 2013 8:44 pm SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Help please! About to embark on building and would advic 6Jan 02, 2013 10:40 am Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Help please! About to embark on building and would advic 7Jan 02, 2013 5:07 pm Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Help please! About to embark on building and would advic 8Jan 02, 2013 8:34 pm SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Help please! About to embark on building and would advic 9Jan 02, 2013 9:17 pm Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Help please! About to embark on building and would advic 10Jan 02, 2013 9:19 pm SunshineT's Build: viewtopic.php?f=31&t=34585 Designs start: 4/12/09 DA: 5/7/11 Demo: 22/12/11 Slab: 24/2/12 Keys: 31/8/12 Re: Help please! About to embark on building and would advic 11Jan 02, 2013 9:36 pm Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Re: Help please! About to embark on building and would advic 13Jan 05, 2013 10:31 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hope this link works but basically this is why I can't have anything else on the north. It doesn't really fit and still face north. I am also trying to build as affordably as possible and that means the simplest shape. It's a bit of a trade off for build more solar passively, i could build up for instance, and then not have any money left for things like solar hot water or grey water reuse or actually any money for anything at all. I want to keep the actual footprint as cheap to make as possible. It was a good suggestion though considering I hadn't posted that image yet. The patio material I haven't decided yet. It may be a timber or concrete patio, I'm not sure. But I was intending to have some sort of pergola that lets in the winter light and not the summer light. Like a solar pergola or vergola whatever they call them or simply a normal pergola with clear section at the right distance to let in the winter sun which I can cover with reflective material in summer. Something like that anyway. Thanks for the eaves tool as well! I had also thought of the door in the hallway and I will probably do that. As for the bir's. I think, and I could be wrong, that if I put the robes on those walls, it will cut off too much of the room to fit a double bed. Because the rooms are wider then they are long I don't think it's possible to put them along there and not make some long, narrow rooms which are usually a less practical space. So it would be a trade off between a double room and the occasional noise getting through I guess. Still something to consider though. Thanks so much for commenting! Really great ideas. Blog http://tobuildahomeimprobable.blogspot.com.au/ Settlement Apr Council Jul Contracts Dec Earthworks Dec Frames Jan Trusses Feb Roof Feb Windows Mar Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 21520 This is the current bathroom with a european laundry. Overall internal dimensions are 3.69 wide and 3.65m deep, including the footprint of the laundry. There is a toilet… 0 11185 Yes, unless you are in a low intensity rainfall area or the area is protected from rain. Do you have access to NCC Part 2 or can you download it? I can email you a copy… 10 12753 |
