Browse Forums Building A New House 1 Dec 27, 2012 7:48 pm How many LED downlights do people install in their rooms. At first we thought to put 4 LED downlights (16W Brightgreen) in each bedroom, the average room size is 3.5*3.5 with ceiling at 2.4m (28c). Then we've been told that it will be overkill, and been recommended only one such LED downlight per room. After much deliberation we ended up with having 2 LED per bedroom. Now that I downloaded Brightgreen iPhone app - it calculated as 3 LED downlights per room... What should we do??? Re: How many downlights per room? 2Dec 27, 2012 7:57 pm 4 downlights with a fan in the middle. Add a dimmer if you want to drop the light level. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: How many downlights per room? 3Dec 27, 2012 8:00 pm PAB_34 4 downlights with a fan in the middle. Add a dimmer if you want to drop the light level. I was going to suggest a dimmer. I think 4 will look better and dimming them will give you just the right amount of light. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: How many downlights per room? 4Dec 27, 2012 8:03 pm would this also go for a media room? it will have led strip lighting on the cabinets thanks Re: How many downlights per room? 5Dec 27, 2012 8:08 pm We are having 4 downlights in our theatre room on a dimmer. If you have separate LED strip lighting just put them on a different lighting circuit to the downlights. That way you have the choice of whether to have them on or off Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: How many downlights per room? 7Dec 28, 2012 11:12 am Four 16w downlights in a room that size will be very bright. I agree with your builder, two will be more than adequate, especially for bedrooms (where you will also most likely have lamps to supplement). I have 11w throughout my house, and have found all my rooms to be very well lit including those I was worried wouldn't have enough. Re: How many downlights per room? 8Dec 28, 2012 3:01 pm There is an element of personal preference - but the point of downlights is to use the bright narrow beam to light a focused area. So things like kitchen bench or hallways are ideal. We are not using downlights in any of the bedrooms (apart from in our walk-in-robe) but it depends if you want the "neater" look of having all your lights plush into the ceiling. We put downlights into our bedroom in our last house before we sold it and found that when horizontally-positioned (sorry the other word I used is banned in the forums) in bed the direct light would always get in our eyes whereas our previous lights diffused it a lot more. In a couple of the living areas we are not doing anything initially because I want to work out how we are going to use the space once we are living there before deciding what sort of lighting I want - no point filling it with downlights if that is unnecessary or wouldn't work. In terms of lighting requirements, I'd be wary of completely relying on an app provided by a company that sells lights to define how many lights you need - and instead just have a look at similar sized rooms at family/friends houses to see what they've done and whether that is adequate. Demo + Build in Rivervale, Western Australia Moved in June 2014 http://rivervale.tumblr.com/ Building Thread Re: How many downlights per room? 9Dec 29, 2012 6:56 am I agree with the poster above, downlights aren't a great solution for bedrooms and are better suited to 'task' areas like kitchens. Downlights basically light the floor under them in a cone typically between 30 and 55 degrees. For bedrooms you need more diffused light, which is spread more evenly so that it washes the walls and ceiling. A good pendant light in the centre of the room can do this, complemented with a couple of wall sconces or bedside lamps. Much better solution than downlights. Re: How many downlights per room? 10Dec 29, 2012 7:54 am thanks offshore we were going to put downlight in bedroom and now have changed to pendant lights . thinking now to just put a downlight in the wirs 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 3597 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 105564 They already have two well known ones (HIA & MBA) that many new home buyers mistakenly think are regulatory bodies that Joe Public can complain to. 6 18022 |
