Browse Forums Building A New House 1 Dec 16, 2012 8:11 am Hello everyone, This is my first post on this forum a we are at early stages of the process. We have exhanged contracts on a very flat block, 15.24m x 34m. Our cooling off period expires January 7th. We will most probably build with Allworth. The block is in a 1:100 flood zone, however behind the houses across the street, there is a storm water drain. Council have just finished building an easement to protect it. The lovely man we would be dealing with at Allworth drove past yesterday and on this observation alone, thinks the block will need to be raised. He said that if it needs to go more than 1 metre up, then they couldn't build, however to me this sounds very extreme , considering the houses around the block are either not raised, or only raised by 2 rows of bricks. We will get the AHD survey done SOON. Has anyone had a similar situation occur to them? Would it be done by fill or by bricks, and the biggest question of all, is does anyone know how much cost this could add to our build? Any house we build would be approx 200 - 230 metres squared. Finally, does Allworth already build up 300mm, so would this mean we have 700mm more to play with in worst case scenario? I appreciate any feedback and help... we hope everything can work out! Re: Building up a flat block 2Dec 16, 2012 9:48 am We had to raise our slab by 200mm due to the fall of the sewer. Clean fill was brought in to fill it up, then formwork with waffle pods and concrete. It cost approx $8K all up. A lot of the cost was for building stairs at the front of the house, 4 steps were required. The garage stayed at ground level, but as the rest of the house was raised 200mm, we now have a huge garage height, which meant we needed steps to access the house. Luckily we extended our garage 500mm in width, so there was still room to park our car with the steps, not that we'll do that for a while, we have so much stuff, lol! Are you waiting for a tender from Allworth? Wait and see how much it cost from them. Worst case senario, if it is really expensive, then shop around other builders and maybe get another tender from someone else to compare. You might even consider a custom builder. Good luck! We built the Wisdom Majestic 40 - moved in! Our blog - http://ourwisdommajestic40.blogspot.com.au/ Our H1 thread - viewtopic.php?t=54156 Re: Building up a flat block 3Dec 16, 2012 5:30 pm Thanks for your reply We assumed it would be around that price, but I guess we'll never know until the AHD survey comes back. Thanks for your advice too- at the end of the day, something will work out! Cheers, Stacey I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4123 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13906 Any advice on how to ensure the kit home granny flat that im thinking of buying will get council approval. The kit home companys wont release plans without a deposit and… 0 7222 |
