Browse Forums Building A New House 1 Dec 12, 2012 4:42 am Hi guys, I'm trying to learn to do material take off for external & internal wall frames. I came across this site http://www.blocklayer.com/Wall-Framing.aspx Can someone explain what are Corners, Ends and Spaces on a floor plan? Thanks Re: Framing material takeoff 2Dec 14, 2012 11:20 am Corner is where 2 walls run at right angles to each other. this usually requires an additional stud and plaster angle end is simply the end of a wall. requires an additional stud (even when it butts up to another wall) An opening requires an additional studd on either side to hold the lintel above it. Not sure what the mean by a space. This is not an Australian site so the terminology is a bit different. the only thing i can think of is that perhaps it is referring to an internal void (such as a Return Air for ducted heating or a fridge space or WIR area) "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Re: Framing material takeoff 3Dec 14, 2012 1:11 pm Despite the .com at the end I think it is an Australian site kid81. At the bottom is contact Greg Tarrant ph: (Australia) +61 7 40987645 mob: 043 816 5753 I could be wrong though... I've been to this site and recommended it numerous times to other people. It has some excellent calculators and info for tradies and non-tradies alike. Stewie Re: Framing material takeoff 4Dec 14, 2012 4:13 pm kid81 Corner is where 2 walls run at right angles to each other. this usually requires an additional stud and plaster angle end is simply the end of a wall. requires an additional stud (even when it butts up to another wall) An opening requires an additional studd on either side to hold the lintel above it. Not sure what the mean by a space. This is not an Australian site so the terminology is a bit different. the only thing i can think of is that perhaps it is referring to an internal void (such as a Return Air for ducted heating or a fridge space or WIR area) Thanks mate Re: Framing material takeoff 5Dec 17, 2012 2:14 pm Stewie D Despite the .com at the end I think it is an Australian site kid81. At the bottom is contact Greg Tarrant ph: (Australia) +61 7 40987645 mob: 043 816 5753 I could be wrong though... I've been to this site and recommended it numerous times to other people. It has some excellent calculators and info for tradies and non-tradies alike. Stewie Fair point mate. I was just assuming from the terminology. Didnt think to check that it may have been from WA. They might as well be international from us here on the East Coast!!! (joking) "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Re: Framing material takeoff 7Dec 18, 2012 7:44 am Fair point bkm but for a general guide it is pretty close and for someone trying to work out what their framing costs will be for a reno it is accurate enough which is what the OP is trying to do. Stewie ( semi-retired builder ) STEFF62 Framing should be fine, but he will only be able to nail the baseplates in, I wouldnt think you can dynabolt them after 24 hours. My question is, how is he… 1 5860 8 9921 Houses have been framed on floor joists since settlement, chipboard flooring is only around for 50 years or so, so why would it not be satisfactory? However exercise skill… 3 16842 |
