Browse Forums Building A New House 1 Dec 11, 2012 10:39 am Hi All, Need to have some sort of gutter protection system installed due to a large tree overhanging the roof. So far I have discovered 3 types - Colorbond Mesh, Aluminium Mesh and a Plastic Mesh. I have a colorbond roof and all 3 come profiled to fit the shape of the roof and the fitting systems are all similar. I am in Queens Park so fire risk is not an issue, just wondering if anyone has any experience with any of there? Thanks! Re: Gutter Guard Recommendations in Perth? 2Jan 26, 2013 7:57 am We also have large trees over the house - eucalyptus. (in Sydney). Interested to see what people recommend - some threads here say any type of gutter guard is a waste of time as you have to remove it to get rid of sediment etc underneath. We don't have any at the moment and my partner gets up 3-4 times a year to clean out the leaves. As he gets older - wondering if we should just pay someone to do this rather than paying for guard that would still need manually cleaning. Re: Gutter Guard Recommendations in Perth? 3Jan 26, 2013 2:21 pm If done during the building stage, the only one that should be considered is the surface adhesion Leaf Safe Guttering system. It fits standard size guttering. http://www.leafsafeguttering.com.au/ After market mesh types all have cross flushing issues due to the disruption of flow off the roof. The Fielders Watergate is zinc, easy to DIY install, is available in packs of 8 X 1.25 metres and costs about $40 a pack. Look for it in the garden section at Bunnings. Leave access gaps every couple of lengths. A few leaves getting in won't be a problem. http://www.fielders.com.au/aspx/Watergate.aspx 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Gutter Guard Recommendations in Perth? 4Mar 03, 2013 5:00 pm SaveH2O If done during the building stage, the only one that should be considered is the surface adhesion Leaf Safe Guttering system. It fits standard size guttering. http://www.leafsafeguttering.com.au/ After market mesh types all have cross flushing issues due to the disruption of flow off the roof. The Fielders Watergate is zinc, easy to DIY install, is available in packs of 8 X 1.25 metres and costs about $40 a pack. Look for it in the garden section at Bunnings. Leave access gaps every couple of lengths. A few leaves getting in won't be a problem. http://www.fielders.com.au/aspx/Watergate.aspx Thanks - will check it out, looks good No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 4938 DIY, Home Maintenance & Repair This is a very challenging situation, made much harder by not being on site. Firstly, I think that I originally… 10 8991 Thank you so much. We ended going with the terrain that’s part of our brick. 2 2545 |
