Browse Forums Building A New House 1 Nov 27, 2012 8:56 pm Today builder emailed me: "*** would like to inform you that we have now completed the slab stage of construction of your new home. The next phase of your new home will be the house timber frame which is due to commence shortly." Shall I have an inspection to the site with supervisor at this stage? Thanks. Re: Shall I check the site after slab being done? 2Nov 28, 2012 4:54 am It never does any harm to inspect. If nothing else it shows the SS you are interested in the quality of the house and encourage more care on future stages. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Shall I check the site after slab being done? 3Nov 29, 2012 10:03 pm bashworth It never does any harm to inspect. If nothing else it shows the SS you are interested in the quality of the house and encourage more care on future stages. Thanks for your advise. Can we book a time with supervisor to have an inspection during weekend? Or normally only weekdays? Re: Shall I check the site after slab being done? 4Nov 30, 2012 4:43 am Most builders work Monday to Friday. As they usually start early first thing may be best. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Shall I check the site after slab being done? 5Nov 30, 2012 7:48 am I had the slab inspected at the frame stage - mostly because they got the frame done so quickly I had no time to react to the slab pour. Amongst other things during the inspection they found a >14mm drop in one piece of the slab in the living room. I don't know what they've done to actually fix this, but they claim to have done so. Building a Delta 21 at Craigieburn - http://homeofzero.blogspot.com.au/ Deposit: 26/02. Contract: 22/05. Settlement: 29/05. Site start: 18/10. Shall I check the site after slab being done? 6Nov 30, 2012 8:29 am I checked and measured the slab to find that the garage was too deep encroaching on the already small powder room behind, width of the alfresco step treads too narrow and the slab under the pergola was 600mm too narrow. Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 12099 i would suggest nothing is unreasonable for PCI. we did all sorts, including checking the hot water, checking all the GPO's had power, testing that the showers were… 9 98952 My garage door has started playing up recently. Sometimes (and getting more frequent) when I press the button to open it, it wont. The motor is an ATA GD0-6V3. Red and… 0 2846 |
