Browse Forums Building A New House 1 Nov 27, 2012 10:03 am Hi Some help and advice of flashing! My front right flashing is facing in towards my home, this is not correct is it? It should be angled away from my home so as not have water collect in the flashing and seep in to my walls and create rot and leakage. This is a defect and should be rectified? cheers I know this post is from a while ago, but the VBA has some good guidance on this. https://www.vba.vic.gov.au/__data/asset ... 5-Roof.pdf 2 10626 AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6278 Building Standards; Getting It Right! There doesn't look to be any rebate in the slab to prevent water from scooting under the window. AS4654 is the Australian standard to look at/refer to. They have… 1 10157 |
