Browse Forums Building A New House 1 Nov 27, 2012 8:40 am Hi, Could someone please advise as to what my NBN points in the garage of my new home should look like? I have seen other garages in my estate and some have panels next to the nbn data points and power points and looks very neat and organised, other garages have lock boxes which look great. My garage has nbn data points, power points and a hole in the wall with orange cables hanging out. Is this right? Is my builder cutting corners and doing a scrappy half assed job? PLEASE HELP!!! Re: NBN data points in brand new home 2Nov 27, 2012 8:53 am As far as i know, your builder just sets up your cables and its up to you to get your NBN organized.. Your NBN contractor can set them all up in a nice neat box at an extra cost you would also need to organize any additional switches/routers you may need depending on how many data points you have. Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: NBN data points in brand new home 3Nov 27, 2012 8:53 am The builder appears to have done their bit from what you have described (ie. set up the wired network cabling in your home) - you can say you want a cabinet when you organise for an NBNCo contractor to come and install the NTD box on your wall if you wish (that's why you just have a hole in the wall with some wires sticking out at the moment, because the NBNCo contractor hasn't come out yet). Some people apparently have nothing better to do than comment on other people's sigs. Re: NBN data points in brand new home 4Nov 27, 2012 9:02 am Thanks for the info. nbn isnt up and running in my estate/area as yet. However from my original post - is it safe to say that some builders will supply or make neat that nbn data section in the garage and others dont? as i mentioned some have lock boxes others a nice panel. i dont have a case in getting this neatened etc by my builder? i have to wait for nbn contractor and pay a bit more for the box to cover the area? cheers Re: NBN data points in brand new home 5Nov 27, 2012 9:29 am If you havent asked the builder to supply and install and data panel, they wont do it, people who have panels probablly installed that themselved (we will be doing that at some point after the build) but the builder just does the connection and usually it would be cables coming out of the wall and power points thats all... Building Henley Monaco Nouveau Q1 - Mernda Villages https://forum.homeone.com.au/viewtopic.php?f=31&t=57810 http://razbuild.blogspot.com.au/ Re: NBN data points in brand new home 6Nov 27, 2012 11:07 am ... and if you do get them (the builder) to install the network hub and cabinet you'll be paying their inflated prices for the privilege. Whenever we end up getting NBNCo to extend the greenfields rollout into the brownfields part of my development I'll be getting a cat6 ethernet cable run put in from the position in the garage where the NTD will go to my study (where my router lives). I already have existing cat 6 runs from there to the lounge / rumpus where data is also needed and I'd rather have the router itself inside to get better wireless signal penetration into the living area/bedrooms, as well as not having to go into the garage to get to the router if it ever needs to be cycled (it also makes it easier for me to set up a NAS if I ever want to do so down the track). Some people apparently have nothing better to do than comment on other people's sigs. If you're referring to Eufy homebase, then just put a switch between a datapoint and put the homebase elsewhere near another device in your home unless you want teh… 9 13864 I am in a difficult situation. Long story short I have been handed over my brand new home in Sydney with everything in the house being great except the windows that were… 0 972 Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20677 |
