Browse Forums Building A New House 1 Nov 21, 2012 11:35 pm Hi guys! Need to tap into the wisdom of this forum. Both hubby and I are clueless when it comes to building.. Basically we are in a situation where we can choose between 2 different houses. One is from the mid range of a popular builder, the other is the top range. Hubby is pretty set on 1 particular floor plan, which is mid range. He doesn't care that he could paying just about the same for another house with marginally higher quality - but my mind set is, premium range, premium fittings?? I went to the selection centre, and wept when I saw the toilet from the mid range, it seems very trivial but I am disappointed that we can't even upgrade to a better toilet across the range! I'm hoping for any opinions on any of the following, if not all! BRICKS Austral vs Boral? or Hebel? I am leaning towards hebel. ALFRESCO is it advisable to leave it for later? With the top range we have the alfresco included, but with mid range we have to pay $10k for it which I would much rather leave out. ELECTRICALS What can we leave for our own electrician to do later? Home theatre cabling? TV mounting? Security system? Ducted vacuum system? TBC.. Re: Building a new home: Decisions.. decisions.. HELP! 2Nov 21, 2012 11:59 pm Bricks .. we had Hebel on our first home. Fine cracks started to appear along the joins within a year. From some angles, the individual panels can be very visible. Alfresco .. if you want one, it should be done now. It incorporates the roof and slab. To do this after isn't feasible - your only option would be paving/concrete and pergola, etc. Electricals .. depends on your builder. One suggestion may be to simply have the builder get the house to lockup, and you engage your own contractors for the rest of the internal fitout. You'll have far more control over the selections available to you, as well as more control over the cost. As for layout, if the cost difference is not huge, amortise this over the life of the loan and see how much extra per year it will cost you for the layout you really want. In those terms, it may be worthwhile, especially if you can make savings on the internals as suggested above. Re: Building a new home: Decisions.. decisions.. HELP! 3Nov 22, 2012 12:43 am Get the best you can afford. You will never get around to changing it later. Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 2986 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 1279 Skjm You might want to watch this video: https://www.youtube.com/watch?v=CKx-bsOr2jg If that link doesn't work go to youtube and search for Zac Homes ACA I am really… 1 3060 |
