Browse Forums Building A New House Re: Building a modified Coral Noosa 279 - Wall Frames Up 61Dec 06, 2012 9:34 pm The smaller roof frames are up, over the front and back rooms. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The larger trusses are still waiting on the crane. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our power is connected - and no smart meter either. I'll always remember the day they rolled over to 1. Day: 25 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 62Dec 07, 2012 9:10 pm The crane showed up today... but I missed it. In less than two hours they had the main roof trusses stood up and bolted in place. Windows and sliding doors did not arrive today. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There seems to be a lot of smaller jobs left to do. A few roof trusses still need to go up, as does the entry of the facade, and various roof pieces - rafters, battens etc. They've started bolting down the frame to the slab and I imagine after that's done they can cut the frame pieces that are currently running along the bottom of the doorways. We're told the fascias and gutters will come in Tuesday and by the end of next week we'll have the roof on. Brick layers are scheduled to start too - but no date yet as they're finishing another job. The aim is to have the brick work done by the Christmas shutdown, and no rough-ins will be done for electrical, plumbing etc due to the risk of theft over the break. Day: 26 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 63Dec 13, 2012 12:40 pm I dropped in on the weekend to measure things up. Everything lines up exactly as it should - which is pretty impressive when you consider the scale of it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This is the measurement of the garage, which should be 6790 x 5800. I put the differences (3mm and 1mm) down to my measuring style and a margin of error. Nothing to be concerned about. Tip: If you're going to buy a laser measure, get a pair of laser glasses too. These are basically just red wrap around sunglasses that help you spot the laser dot. It lets you use the measure in bright lighting conditions. One thing I was very happy to see is the roof trusses are spaced at 600mm. I know some other builders will double that truss spacing to 1200mm when you're putting on a Colorbond roof. The reasoning is the Colorbond is a lot lighter than tiles, so they can halve the number of trusses to support it, save some costs and still have a strong enough structure. I'm happy to see our builder hasn't done that. My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 64Dec 13, 2012 12:53 pm Work progresses... a bit slowly. This is the first steel frame this crew has put up and they're taking their time while they figure it out and get it right. The time is all going into the roof components. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The Entry is assembled. Day: 29 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 65Dec 13, 2012 12:57 pm Windows arrive, but aren't installed today. The framing continues... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Day: 30 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 66Dec 13, 2012 1:18 pm Fascias and guttering arrives, and goes up in one day. No down pipes yet. It's great to see some colour on the house. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Oh yeah, a pile of dirt arrived too. I wasn't expecting that and neither were the guys onsite. They were wondering if someone just decided to dump it and run. Doesn't bother me though - it's clean and we can use some fill at the front. They're welcome to dump a bit more! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Day: 31 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 67Dec 13, 2012 2:00 pm I spoke to the carpenters on site yesterday about some framing matters. They tell me they're spending a lot of their time bracing the roof trusses now. They were screwing these pieces in the red box... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ... up here ... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There's a few of them to do. This is just one bundle out the front... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ... there's another bundle inside. The steel wall frames are also delivered as entirely square modules. So they have to cut and fold up a bit of the bottom plate in the doorways, like so... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ There's clearly a lot of smaller steps in this and I'm sure it's more than they'd need to do for a timber frame. I wonder if I'm putting them off working with steel? I'm very happy with the result. It's a good looking product. My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 68Dec 13, 2012 10:37 pm Progress continues with the frame and they're on the home straight now. The roof line looks complete, the bottom plates across all door openings and low windows have been cut and folded up, trusses are bracketed and strapped to walls, and a lot of truss bracing has been screwed up... but I suspect there's a few more left. The house is a lot cleaner too, they're finishing up from the back of the house to front and it appears done right up to the lounge. Pretty good. The carpenters advise me they'll be finishing tomorrow so it looks like they'll need to finish off any remaining bracing (if any), take down the temporary braces here and there, knock up the bath hob, and hopefully they'll fit the windows and sliding doors - it'll be good to see them in place. I'm not sure if the carpenters or roofers will be fitting the battens, but they're there ready to go up too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our dirt pile was levelled today so looks like that was ordered intentionally. Our bricks were delivered too - 12 pallets worth. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The bricks are PGH's Smoke. Our SS's plan was to have them done by the Christmas shut down... but I suspect that's getting a bit too close now. Where-ever they get to will be ok with us. Day: 32 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 69Dec 21, 2012 11:37 pm The frame has definitely slowed things down. There's been a few issues with it - namely some damaged web pieces in the roof trusses and a couple of the window openings are the wrong dimensions. The truss damage isn't too bad, affects about 4 pieces and looks like damage from transit or perhaps from the crane chain when they were lifting them into place. No word yet on a date when it'll be fixed, but everything is tailing off this week anyway. If this is Coral's first experience with the steel frame down here I wonder how the opinion is back in the office. Hopefully these are just growing pains with a new supplier/product. I don't have any regrets, it's a great product and I can see the challenge it getting it together quickly. There's a fair bit to it. I'm posting these pics a week after I took them, so don't go by the posting date. The next few posts show day-to-day from the previous post. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Most of the windows are installed now. Supplies start to roll up for the brickies. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Windows at the rear - kitchen and dining room. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ This truss is interesting. It's still sitting by the fence and looks good to go, but has never been used. There's nothing missing from the roof as far as I can see. A spare, a mistake or just not required for some reason. Day: 33 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 70Dec 21, 2012 11:58 pm We drive past this morning to see more bricks being delivered and came back this afternoon to find not much else has been done. Not much happens for the rest of the week unfortunately. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ A total of 24 pallets of bricks are delivered now. At 380 per pallet that's 9,120 bricks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The dirt pile is gone, now there's sand. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wall wrap is started... and that one piece is all they do today. Day: 36 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 71Dec 22, 2012 12:14 am We almost had a delivery today. My wife just happened to drive past the site when a Lysaght delivery was attempted. The driver was able to leave a few smaller pieces but due to the front yard being wedged with bricks and sand he had to take our 2 tonnes of roof material (Colorbond etc) back to the warehouse. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The anticon insulation was delivered - 23 bags. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The roof safety rails were put up too. I'd say if the roof delivery was able to be dropped somewhere we would have had a roof on this week. Day: 37 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 72Dec 22, 2012 12:16 am Big news today! A sign appeared on our fence. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yep... that's it. There was no lintel delivery either. They just dropped around to put up their sign. Day: 38 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 73Dec 22, 2012 12:31 am A bit of action today as the brickies do more preperation. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The sand pile has been relocated to the back yard. Interestingly the bags of cement delivered the other day have been removed and this new lot has arrived. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Lintel bars are delivered too. But they're not from the guys who put the ad on the fence. This only just occurred to me - opportunistic advertising perhaps? I think I'll go cut that sign down tomorrow. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Our bricks have started! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ... well, they've just started to make a ramp to help them move the sand. Day: 39 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 74Dec 22, 2012 12:39 am The brickies are still getting some things done. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Another day, another pile of sand. They've wrapped the rest of the house too. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Wall wrap / vapour barrier / sarking at rear. Looks like they're good to go for getting the bricks done now, but I suspect we might have hit the Christmas shut down. If they're motivated they might show up tomorrow (Sat) and Monday. I'll wait and see. Day: 40 My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 75Dec 22, 2012 5:30 am house looking great we nearly went with steel frames but de to christmas and a long wait went with timber hope the brickies start today for you Re: Building a modified Coral Noosa 279 - Wall Frames Up 76Dec 22, 2012 7:31 am 1rocky house looking great we nearly went with steel frames but de to christmas and a long wait went with timber hope the brickies start today for you Hi 1rocky, shame to hear about the wait. How long was the wait they were quoting? I get the impression that Stoddart are picking up a lot of work for their frames now, perhaps that's translating to delays. They've told us they're bringing up a new factory in Newcastle, NSW. Hopefully that will address things soon. We received notice from Coral yesterday that are closing the build for Christmas, according to the contract that's a 5 week period. Based on that I'd be surprised if the brickies started anything significant - i.e. starting a job just for a day or two, laying a few bricks and then knocking off for a couple of weeks. We were told a while ago that different trades stop for different times and the builders shutdown period is just a generic cover all. Hopefully the brickies won't be off until February, everyone else seems to quote mid-January as the restart date. My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 77Dec 26, 2012 11:47 am No further work was done after the house was wrapped. We're in the Christmas shutdown now. Hopefully it won't be too long before they're back on the job. My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Wall Frames Up 78Dec 27, 2012 6:33 am we live on the north coast and wait was close to feb or longer before delivery but the builder was great and organized termimesh at no extra cost and a concrete pad at the side of the laundry for us. so we are very pleased . we asked coral homes before we went with our builder but they would not build on our block. but they have nice homes and the display home here is awesome . congrats on all the work being done our tradies are back on site 7th jan and we have the brickies coming in on the 14th jan after termimesh is installed we have been told if weather is good we will have lock up by end of jan just looked through your thread again and your home is awesome Re: Building a modified Coral Noosa 279 - Wall Frames Up 79Dec 27, 2012 3:58 pm 1rocky we live on the north coast and wait was close to feb or longer before delivery but the builder was great and organized termimesh at no extra cost and a concrete pad at the side of the laundry for us. so we are very pleased . we asked coral homes before we went with our builder but they would not build on our block. but they have nice homes and the display home here is awesome . congrats on all the work being done Hi 1rocky. Do you have a build thread going? That's a shame about Coral but it sounds like you've found a good builder there. Does your block have a steep slope? 1rocky our tradies are back on site 7th jan and we have the brickies coming in on the 14th jan after termimesh is installed we have been told if weather is good we will have lock up by end of jan just looked through your thread again and your home is awesome Thanks mate and great stuff on those dates too. It's so easy to get impatient with a build and start thinking, Couldn't they have just finished x?!??! We drove past a Masterton build today and they had a team of brickies there working away. Good to see that not every tradie disappears over Christmas. I've looked into Termimesh before too, it's great stuff. I like any of the termite barriers that don't require a ring of pesticide around the house, there's a few good ones. My Build Thread: Coral Homes Noosa 279 Re: Building a modified Coral Noosa 279 - Waiting for bricks 80Dec 27, 2012 4:03 pm thanks thattime i have not got a build thread but will start one now Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13816 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4360 |
