Browse Forums Building A New House 1 Nov 16, 2012 5:27 pm We are almost ready to put our names to the tender but can't decide if we should put windows in the garage. Every house that I have been too has windows with coverings. But the coverings are always closed. This makes me think don't worry about it. Also if we want to put some type of shelves in at a later stage the window would be in the way. If the blinds are always closed - why bother ? Also, just another extra cost to have them covered ? We would welcome some suggestions on this one ..... thanks again ! P.S Hubby is no handy man so it's not likely he will be in the garage tinkering around Re: Windows in garage ? 2Nov 16, 2012 5:46 pm If you ever consider converting garage to a room the windows would come in handy but other than that they aren't all that necessary. it is something we considered but that's about all the input I can give you regarding that. They are also handy if you set up workshop in your garage and want some natural sunlight/ventilation in the garage. HOpe this helps Oct 10 - Council Approval Oct 23 - Site scrape Oct 29 - Footings and Prelay OCT 30 - Slabbed Nov 6 - Bricks Delivered Nov 13 - Brickwork started Re: Windows in garage ? 3Nov 16, 2012 5:51 pm may be a second door instead? some say it's good when you want to add some stuff onto your backyard etc instead of walking around or dragging things through the house RWife Re: Windows in garage ? 4Nov 16, 2012 6:26 pm magical P.S Hubby is no handy man so it's not likely he will be in the garage tinkering around This makes me think it may be a waste of money; unless you think you might want to convert it to a room (which will mean quite a lot of windows), it's probably not worth it. Having no windows also means that if you want to hang stuff on walls etc it's a lot easier. The door idea, though, sounds pretty useful! Surrey Hills, Vic 3127 Garage is being built with metal, 3m distance away from my cover deck. It is parallel to my cover deck, living room, family room and kitchen,… 0 9611 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17191 |
