Hi,
So the mortar is now fixed and looks great, but now I can see all the brickwork flaws a bit better...
Does this look like acid burn?
Or is just the brick flaws?
Is it possible to be fixed? From what I understand you cannot fix it.
The brick is Austral Hawksburn and the mortar was recently re-done, they did not use acid so any acid burn must be from the original bricklayer. From a distance it looks great, only close up I can see all the flaws.
Thanks
