Browse Forums Building A New House 1 Apr 04, 2008 8:27 am When we went to have a peek at our house earlier this week, we noticed that they have put what I can only explain as a draft stopper brush strip (which you usually see on the bottom of a front door) onto the bottom of the bathroom and laundry doors (internal doors).
I've never seen this before and was wondering if anyone else has this in their house? From reading the Building Standards and Tolerances (thanks jamiet) it states that the gap under a door should not be more than 20mm with floor coverings laid. Would it be that the builder has seen that the gap is greater than 2cm, and put this on to fix the problem? Is this an acceptable solution? I personally don't like them... Ray. Second Time 'Round Re: bottom of door to floor clearance 2Apr 04, 2008 8:45 am This is a little OT, but when we moved into our current house it featured hideous shag pile throughout. The first thing I did was have it all ripped out and the beautiful Tasmanian Oak floorboards polished. But now we have huge gaps under the doors. I might take your idea and put in some draft stoppers. Just need to find some subtle ones that won;t look weird on the original 1920s doors. Re: bottom of door to floor clearance 3Apr 04, 2008 1:21 pm It will be to stop air movement - these rooms need to have ventilation, and without the brishg strip air movment would be greater, and the rest of the hosue will be cooler.
I'd be tipping it is a basix requirment somewhere. Steve Building Standards; Getting It Right! When my house was built (over 7 years ago), the post brackets were done to allow for concrete porch, but they didn’t allow for the planned stone paving. I’m finally… 0 1913 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16561 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17525 |
