Browse Forums Building A New House Re: Neighbour's tin roof causing glare 2Oct 19, 2012 9:16 pm me_me1983 Hi everyone, Just building a new house, and the neighbour has built a tin roof with glare coming off the sun. Anyone know if a tin roof fades over time? Just don't want to wear my sunnies everytime I go outside Same prob at my place where we are building. Do you know if its a colourbond colour or Zincalume not sure if spelt correctly. We had a Zincalume on our first home dont worry it does dull down. Not sure about the colourbond though. I think our new neighbours roof is the Surfmist colour. Re: Neighbour's tin roof causing glare 3Nov 04, 2012 3:10 pm I'm trying to rule out Surfmist for the same reason. It will settle, but in the meantime glare is immense. Which way is the house facing? I'm wondering whether north front-facing would be far worse than others; because some are glary much at all. Re: Neighbour's tin roof causing glare 4Nov 04, 2012 6:53 pm Our friends neighbour has a surfmist roof and the sun glares off it. A bonus though is that the heat boosts their solar panels!!! Feel free to follow our build! viewtopic.php?f=31&t=59958 Re: Neighbour's tin roof causing glare 5Nov 05, 2012 2:09 pm Solar panels actually work better if they are kept cool that's why they are a little more efficient if they are on racks and not mounted closer to the roof iron Re: Neighbour's tin roof causing glare 6Nov 05, 2012 2:58 pm Our neighbour at the back, where our alfresco is has a surfmist roof and when we moved in it was unbearable. Now we don't even notice it. Not sure if its faded or if we just got used to it. The road to success is always under construction House completed April 2011 - slowly making it a home... Re: Neighbour's tin roof causing glare 7Nov 05, 2012 3:28 pm sceen7 Solar panels actually work better if they are kept cool that's why they are a little more efficient if they are on racks and not mounted closer to the roof iron Depends on whether they are hot water solar panels or photovoltaic solar panels Demolition August 2009, Construction Started September 2009, Completed December 2010 2 9448 This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28321 traditional gable roof facade - Have you did the dark and light gray color combination in facade with gray stone in facade… 0 4212 |
