Browse Forums Building A New House Re: Building with Sekisui in Mount Barker 2Oct 14, 2012 6:13 pm Hi bilal, exciting times ahead for you! Can you post a picture of your plans? Is your block on acreage or in Mt Barker itself? Re: Building with Sekisui in Mount Barker 3Oct 17, 2012 7:00 pm Treeseachanger Hi bilal, exciting times ahead for you! Can you post a picture of your plans? Is your block on acreage or in Mt Barker itself? I am trying to post some photos but can't figure out how to do it, anyone can help? Re: Building with Sekisui in Mount Barker 4Oct 19, 2012 3:57 pm You must register with an external storage site such as imageshack or photobucket, upload to site, then you are given the codes to post to forums. It's the img code you need. Our Half Acre Heaven viewtopic.php?f=31&t=60147 If what you describe is correct then the brick wall has been dry lined with villa board. That basically means that the villa board is glued to the brick wall with… 3 8350 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110768 |
