Browse Forums Building A New House 1 Oct 11, 2012 5:48 pm What do you do with the leftover bricks when your brickwork is finished? Are you allowed to keep these bricks or do brickies claim them? Just thinking about letter box later down the road... How many bricks would you need to make one? Would I need to buy bricks later or can I keep some of the ones that's been left? Is there a preference in bricks: internal wall red brick or face bricks? (Mail box will be rendered). Leftover bricks 2Oct 11, 2012 6:29 pm Usually if you ask you SS you can keep them, but you will have to move them to the back corner of your block, and pretty quick or they will get cleaned up and taken away Building again . . with Redink Pre-start 04/12 Keys - 03/13 Finishing off. . . Painting/Floor Tiles/Carpet - 04/13 Walk In Robe/Lighting/Blinds and Moving 05/13 Gates/Front Landscaping / Pool 05/13 Re: Leftover bricks 3Oct 11, 2012 6:37 pm dont know about yr builder, but some of ours were used by the tilers later on, to build up around the baths and the hobs/risers around the showers/baths. so i wouldnt go moving them all yet just in case. [unless of course you havent got the risers and hobs. Re: Leftover bricks 4Oct 11, 2012 7:21 pm Builders would rather you kept any left over bricks as otherwise it costs them to have them carted away. As others have said, you'll have to move them aside since builders will want to leave the site clean. Demolition August 2009, Construction Started September 2009, Completed December 2010 Leftover bricks 6Oct 11, 2012 11:20 pm We used ours as fill under the pavers in our pergola. Jasmin Hickinbotham Belmont - modified Signed: February 2011 Slab should go down before 2012 My build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=52310&p=799483#p799483 Re: Leftover bricks 7Oct 11, 2012 11:56 pm How many bricks would you need to make letter box similar to the one in the picture? Does it make difference if the bricks are internal (red ones) or face bricks? Re: Leftover bricks 8Oct 12, 2012 6:14 pm Bricks are 230x110x76 mm. Mortar joins are 10 mm. From this you can work out the number required. Since the letter box is rendered, either face or common bricks will work, whichever you have left over. if buying more, get common bricks since they are cheaper. Where would you get the nice metal letter box from? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Leftover bricks 9Oct 14, 2012 9:16 am @AubinGroveFan I know its only an image, but that looks super low? Australia post have a minimum height requirement... If its lower they wont deliver your mail Check out our blog below! We are using iDraft and Cozzcorp for our build http://ridgydidge1460.blogspot.com Plans: http://www.idraft.com.au Construction: http://www.cozzcorp.com.au Re: Leftover bricks 10Oct 15, 2012 9:44 am We had the builders put the leftover bricks to the side of the house so we could pick them up one weekend (with the same idea, of creating a mailbox once we have moved in). They were more than happy to do that, however I think the neighbours thought it looked a little suss on the day we went to pick them up! Re: Leftover bricks 11Oct 15, 2012 9:49 am That mailbox in the pic above is stupidly low, would expect Aus Post to just throw your letters on top. As for spare bricks my last house was lucky enough to have an entire pallet of pavers left over from the driveway, they were the wrong ones ordered or something, about 700 in total- used them all to make garden edging Build Thread: viewtopic.php?f=31&t=57639 Re: Leftover bricks 12Oct 15, 2012 10:14 am We had a couple of pallets leftover, and our site supervisor called to ask if we wanted to keep any. We said we would like to keep one pallet, thinking about a letterbox, but have since decided to buy a letterbox and now have to get rid of a pallet of bricks ourselves Re: Leftover bricks 13Oct 15, 2012 12:51 pm monkeypantz We had a couple of pallets leftover, and our site supervisor called to ask if we wanted to keep any. We said we would like to keep one pallet, thinking about a letterbox, but have since decided to buy a letterbox and now have to get rid of a pallet of bricks ourselves Ebay them. You would be surprised how many people go looking for bricks. Re: Leftover bricks 14Oct 15, 2012 12:53 pm Banksy1460 @AubinGroveFan I know its only an image, but that looks super low? Australia post have a minimum height requirement... If its lower they wont deliver your mail I was going to say the same ^^^. Height minimum is apparently 1m from ground to mail slot. Might be a good idea to check AusPost website. Re: Leftover bricks 16Oct 15, 2012 9:21 pm We were told we could keep our leftover bricks, and to move them into the back bedrooms for the remainder of the construction so they could then clear the front yard area. Myself, my partner and my brother moved and stacked them up neatly so tradies could still work around them comfortably. A couple weeks before handover was due, we visited the house only to find the bricks gone. Annoying, would rather have just been told upfront we couldn't have them! That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8640 DIY, Home Maintenance & Repair to do it properly you need to dig out the garden and waterproof the outside of the wall. There are some products you can put on the face of the bricks but the water is… 2 4624 |
