Browse Forums Building A New House 1 Oct 09, 2012 5:06 pm Ok, so we have now signed to build on the Sunshine Coast. Our block is north facing. What do I need to cinsider when choosing the siting? I thave no idea at all.... please any advice much appreciated Re: Signed with Plantation...please help with siting advice? 2Oct 09, 2012 6:12 pm Avoid west facing windows - they will let too much afternoon sun and overheat the rooms The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Signed with Plantation...please help with siting advice? 3Oct 09, 2012 6:23 pm North facing as in the front of the block faces north? If so bashworth is right - make sure your bigger windows are on the east and north! Building the Ascot 35 with Carlisle Homes in Pasadena Estate, Clyde VIC My build thread: viewtopic.php?f=31&t=59776 Re: Signed with Plantation...please help with siting advice? 4Oct 10, 2012 8:37 am Thanks for the info. Yes the block faces north, so house will sit north south, just wondering what side to put living areas etc. Thanks Re: Signed with Plantation...please help with siting advice? 5Oct 10, 2012 10:37 am I'd put them on the east so you can have the curtains open in the evening in summer and catch the sea breeze. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Signed with Plantation...please help with siting advice? 6Oct 10, 2012 11:25 am Deffo for QLD you'd want North and East facing windows - remember though that if you want to take advantage of easterly sea breezes it's also good to have some opposing windows of sufficient size to allow the breeze to push the warmer air out of the house in the evening. A west facing window isn't a deal breaker if you can keep the sun off it with a shrub/tree in summer and can minimise heat loss in winder with double glazing (and/or heavy drapes) - indeed it can be useful as a point from which warmer air can be evacuated in a cross-ventilation setup. Some people apparently have nothing better to do than comment on other people's sigs. Re: Signed with Plantation...please help with siting advice? 7Oct 10, 2012 11:51 am Which Plantation home design are you planning to build? ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Signed with Plantation...please help with siting advice? 8Oct 10, 2012 1:21 pm Thanks all. We are building the Doulton Q2. We have only signed on the weekend, so at the very beginning stages, aka pooing pants stage Re: Signed with Plantation...please help with siting advice? 9Oct 10, 2012 2:37 pm The Doulton Q2 has a good layout but as for orientating it on a north facing block, you will comprise some rooms – unless you can change the plans a bit. First thing to decide is where you will spend most of the time in summer, e.g. the alfresco. This will be on the SE corner of the site, this means flipping the plan with the garage on the west (good) small family room windows facing west (bad – but windows can be thin and hooded). To maximise light/breezes in general living area D/S have a opening window as a splashback in the kitchen and have some windows on the east wall of the front living room. U’stairs is where the biggest problem is. The TV room window (which provides light/ventilation to the entire U/S general area) is facing west (bad). This will cook the U/S and hinder any of the heat from D/S rising up. An option.....If the garage was to stay on the east, U/S TV window stays east (good) but the alfresco area will get the afternoon sun in summer – not nice. A solution may be to flip the media room with the alfresco, it will then be on the east, just away from the kitchen. Also be mindful of storage. No matter which plantation home you look at, they don’t seem to get storage layouts right or provide enough, e.g. bed3 door opens onto the robe. Good luck on this bold adventure! ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Signed with Plantation...please help with siting advice? 10Oct 10, 2012 3:25 pm Thanks for that reply. I think I gave the wrong info tho, the front of the house will face north, so the kitchen will be on the west and living on the east, and u/s the tv area will be on the east, bathrooms on the west. We are taking out bedroom 3 and dividing the space into the other two bedrooms, and I have asked for the windows of these rooms to be facing south. I hope this makes sense, and would be interested in your thoughts Re: Signed with Plantation...please help with siting advice? 11Oct 10, 2012 3:28 pm chillyolanda so at the very beginning stages, aka pooing pants stage Soon to be followed by the 'What the hell have I done stage' and the 'Honey if you don't behave yourself in the tile shop I want a divorce' stage... PAB_34 The Doulton Q2 has a good layout but as for orientating it on a north facing block, you will comprise some rooms – unless you can change the plans a bit. I agree with all the points that PAB has made - Its a lovely plan but how well it works with the orientation of your block is debatable. Not sure how good Plantation are with changes - as with most project builders I would guess like a wounded bull? Problem with a North/South facing block is that at least one side is going to get baked by the Western sun Re: Signed with Plantation...please help with siting advice? 12Oct 10, 2012 3:39 pm Your info was fine - the garage is going to be on the NE corner of the block, alfresco on the SW corner. As I mentioned, give some thought to the alfresco and how much you will want to use it in summer as this will be a hot area. We had an open alfresco area facing west with solid walls to the south and east and it was pretty much un-usable till the sun went down in summer, it was open to the north so it did pick up a little breeze which cooled it down after dark. Good move sorting out the bedrooms, Plantation are pretty good with moving things around as long as it does not interfere with any load bearing walls. ----------------------------------------------- http://pab34newdigs.blogspot.com.au/ ----------------------------------------------- Re: Signed with Plantation...please help with siting advice? 13Oct 10, 2012 3:45 pm thanks. Unfortunately the neighbours on the eastern side have a two story house facing our block, so if we move the alfresco to the east side they will look right down on it will check out options tho Re: Signed with Plantation...please help with siting advice? 14Oct 11, 2012 6:50 am lol atom ute! Can't wait for those stages Re: Signed with Plantation...please help with siting advice? 15Oct 11, 2012 12:35 pm chillyolanda We are taking out bedroom 3 and dividing the space into the other two bedrooms, and I have asked for the windows of these rooms to be facing south. I hope this makes sense, and would be interested in your thoughts If you can find extra space elsewhere without taking out a bedroom, I would recommend that. We did a similar thing with our first build - we took out a 4th bedroom so that the bed 2 & 3 would be bigger - it also allowed us to have separate 'Tv' area. It worked out really well for us - we enjoyed having the extra space. However when we went to sell, we found that despite having a similar sized home and fittings as other 4 bedders in the area, we were categorised with all the other 3 bedroom houses - which were actually smaller and had lower quality fittings. We felt that we missed out on a number of buyers who were looking for a 4 bedroom house and as such it impacted the sale price. What I learned is that when designing your house, not only do you have to be mindful of what you want, but you also have to take into consideration what others may want in the likely event that you do sell in the future. After all you don't want to be the only 300m2 house in the area with only 3 bedrooms. Other option is to make sure that the study downstairs is fully enclosed - then you can market it as a bedroom if you need to. Re: Signed with Plantation...please help with siting advice? 16Oct 11, 2012 1:02 pm I should have also mentioned, we are changing the study into a bedrooma nd adding a shower to the powdwer room downstairs, so still will have 4 bedrooms. Re: Signed with Plantation...please help with siting advice? 17Oct 14, 2012 4:24 pm Looking forward to seeing your build! We are building with Plantat!on too (Maya 4). Settlement: 10.02.13 Slab: 06.03.13 Frame: 08.03.13 Lock-up: 05.04.13 Handover: 03.06.13 Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=59555 Brisbane Photography Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17506 A question. Im in Queensland and building a new home. We managed to reach practical completion 6 weeks ago but we haven't heard any date for handover yet. Who should we… 0 5806 I was being kind to the builder. With the amount charged for the upgrade the builder is probably charging closer to 100% margin. There are a few variables as I… 5 14307 |
