Browse Forums Building A New House 1 Oct 01, 2012 5:43 pm We are looking at building our Second Home. Our first home was a bit of a rush so we could get the large first home buyers Grant. My wife was thinking about buying an established home to avoid some of the stress of building. But we have gone ahead and brought a block since the price seemed to be good. So we have been concentrating on getting the land settled first (30 day settlement) But we have been dabbling, at looking at floor plans. So my question is. You look at the standard plans and then start adding the bits to make it a home and the price of the additions goes ballistic. So when should you start saying to yourself "should I be looking at a private builder"? Is it at certain total cost per sqm? 1k for Computer 6 network points. 20k to add 4 x 400mm to the length of the house (we had a different amount of about 8k for 3x300mm from the same building company, different person) $500 for in cavity sliding door each (tall doors) $100 per downlight $15k for Alfresco $3 for Solar Panels and wall insulation, but it might not be for internal walls. etc. and you see the total cost going up and up. From a base of $181k to an approx build of $260k and that still leaves parts that need to be done post build due to restrictions. So as you can see we are just at the early stages. Any way looking forward to hearing from you and sharing our Journey. DJKLSiv Re: DJKLSiv Pointing at a Home-Time to call the Private Buil 2Oct 23, 2012 6:51 am hi. one thing is for sure. the price per m2 is not the answer. i did a recent spreadsheet and found my prices for the last twelve jobs ranged from $700 to $1600 m2. this does include on site costs and the specifications really vary a lot. size matters. cheers Old Home Restoration / Renovation I have a bad water leak through my window frame every time it's rains heavy. I have been advised the brick work on the side of my house needs repointing. Will rendering… 0 13219 If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 25866 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11759 |
