NOMINAL CEILING HEIGHT - ours seems to be way under!!!
we are supposed to have 2590mm NOMINAL ceiling height!
my measurement today is 2570mm!!
that is without plaster or floor coverings!
so once they are installed it's say our finished height would be close to say 2540mm
being 50mm UNDER what we thought would be our ceiling height.
so is this acceptable?? what is "nominal" and can the builder get away with this?
2440mm (standard)
2590m (8/12ft)
2740mm (9ft)
2990mm
Generally I thought carpenters worked in lots of 75mm/150mm
pretty high LOL
"o/a plates 2570"
contact says nominal ceiling height 2590
But check your plans, project builders always allow for 2400mm and then you pay 10k extra for 2700mm.
side elevation plan says
"o/a plates 2570"
if you check the henley website in inclusions for the sahara q1, you will see it clearly stated there. it's even printed on the web.
The contract and plans are different,
Framing was done as per plans not contract. Carpenters wouldn't know what's in the contract.
50mm isn't huge, but I'll be asking them for a substantial discount as they are unlikely going to fix it, it's not a simple fix like taking off the roof/posi trusses and adding a 90x45mm pine on top of the existing frames.
I feel for you, good luck. Stand your ground and get a substantial discount.
If your still around what happened with this I think we have the same issue?
4
Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for…
24/09/2023
4
Using a rivet sounds like a good idea thanks
15/01/2024
I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to…
