Browse Forums Building A New House Re: Cost of building with Colorbond vs Tile roof 21Oct 05, 2012 11:56 am ^ as Tash said, we also chose a colorbond roof because no one else was using tiles lol So glad we did too - suits the house alot better. Coral charged roughly $5000 for this upgrade. To be honest I don't really get why it costs so much more, as we were told that the house requires more structural support with tiles - hence more materials? Building our first home - Thread: viewtopic.php?f=31&t=60033 Re: Cost of building with Colorbond vs Tile roof 22Oct 07, 2012 8:09 am I was informed the trusses had to be bigger or more of them or similar. That was the justification for the extra cost apparently Cost of building with Colorbond vs Tile roof 23Oct 07, 2012 8:27 am No charge for colorbond with our builder. Re: Cost of building with Colorbond vs Tile roof 24Oct 07, 2012 9:12 am Colourbond was included as standard from the beginning in our home - we had a few other things as standard that most people don't (Caesarstone benchtops in kitchen and bathrooms, 1200mm front door, driveway, etc), obviously the start off price was higher but it's less to add on later! 1st build: viewtopic.php?f=31&t=59376 *New*-2nd build: viewtopic.php?f=31&t=70324&p=1154282#p1154282 Re: Cost of building with Colorbond vs Tile roof 25Oct 07, 2012 9:35 am No extra charge for colorbond for us either. As previously mentioned - I think a tin roof is cheaper for the builder - less reinforcement required in the roof trusses - not as heavy. Usually quicker to install too. Re: Cost of building with Colorbond vs Tile roof 26Oct 07, 2012 10:45 am We have been charged $4,600 extra for colorbond (volume builder). We had no choice - it is a part of our development covenants. Every builder we talked to charged quite a bit extra for colorbond. I think they can get tiles very very cheaply as their standard product because they buy 100s of houses worth of tiles from the same suppliers, but colorbond as a non standard product is more expensive for a builder because they don't get the volume discount. And of course, any opportunity to increase their profits on the house! Tender /1/12 Contract 14/6/12 Planning 12/10/12 Site 23/10/12 Piers 27/11/12 Slab 12/12/12 Frame 15/12/12 Trusses 17/1/13 Roof 24/1/13 Bricks 13/2/13 Plaster 1/3/13 Re: Cost of building with Colorbond vs Tile roof 27Oct 08, 2012 6:21 pm You should also be wary if you are building near coastal water my understanding is that warranty for metal sheeting changes as you get closer to the water. Coastal areas if the right metal sheeting is used will cost more. As it is not standard sheeting the builder is suppose to use but their upgraded product. However most builders still use the standard sheeting that will not be covered by warranty. Re: Cost of building with Colorbond vs Tile roof 28Oct 08, 2012 6:29 pm There you go, coastal conditions require different metal sheeting. You should only pay the difference in cost of the standard metal sheeting and the one required in coastal regions. And get proof that you did get the higher grade sheeting. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Cost of building with Colorbond vs Tile roof 29Jul 05, 2013 1:51 pm Consider the added cost of servicing a house Electrical / Cabling and HVAC Wise if you go with a colourbond house. It makes it much more labour intensive in many cases where cables are harder to run in houses on colourbond roofs when getting extra Antenna and Electrical Points etc. Antenna Direct Perth www.antennadirect.com.au 0423919037 Get your home NBN Ready Smart Wiring and Structured Cabling in Perth Antenna Installations | TV Wall Mounting | Data Cabling HD Security Camera Systems / CCTV Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10187 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 17657 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2864 |
