Browse Forums Building A New House roof sarking 3Mar 28, 2008 6:54 pm cookie we found out that clarendon does not install exhaust fans in the ensuite or main bathroom, and they said we could put them ourself if needed but if you had sarking they would have to be ducted as the condensation could run down and drip on the gyprock ceiling Re: Sisilation in roof 4Mar 28, 2008 9:29 pm Anti-con (roof sarking) is mandatory if fiting a metal roof. From memory it adds about R1.5 to the roof insulation. It goes on top of the battens, not between them and the trusses.
I think a bag which covers 15m2 is about $75 - I bought it over a year ago now so don't quote me on that Re: Sisilation in roof 5Mar 31, 2008 8:44 pm Is it a Tiled or Tin roof? If tiled they do put the sisal directly on the trusses or rafters, then they batten on top. There's no other way for a tiled roof. If a tin roof they put the sisal on top of the battens. If you can afford the extra its worth it, you wont be doing it after.
Regards BG It is cellulose fibre blow in insulation. Basically shredded news paper that is blown into the roof space. It was very popular in the late 90's. It's messy stuff and has… 1 16446 ![]() Hi all! I am building a patio over my deck, and I am using the roof extenda brackets to create the fly-over roof another the eaves. It will be approx 3m wide by 4.5m long… 0 9374 Hi all, My home has a steel flat roof and due to having three air conditioners, a satellite dish, a skylight, and an antenna up there, the labour cost to have the sheets… 0 1223 |
