Browse Forums Building A New House 1 Sep 05, 2012 3:57 pm Hi guys, I am in the process of designing 2 "side by side mirror image townhouses" in Melbourne, just got the initial drawings from the architect and would hope to get some feedback/advice. I am slightly concerned about the 4 metre window splashback and island benchtop as i thought it might be too big. but architect said it would look grand and good for resale in the future Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Need advice on my floorplan 2Sep 05, 2012 5:05 pm My first thought after looking through your plans is that they are great! The design is well thought out, and I can't see anything obvious that I would change. The two way bath/ensuite downstairs is a great idea, as is the laundry chute. I also agree about the window splashback, I wouldn't be too concerned about the size as you can put tall cupboards at the end(s) of the kitchen if you are worried about it being too long. I only wish the first draft we had from our architect was so good... Great job. My building thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=56583&start=120 Re: Need advice on my floorplan 3Sep 05, 2012 7:19 pm Your plans look fantastic. I love big island benches, so agree with architect. If i was living there I would cut down the walk in robe in the guest room and extend the pantry which would get every day use. Good luck with your build. Re: Need advice on my floorplan 4Sep 05, 2012 7:38 pm Hi Mel Great Plans. Layout is really functional with some lovely features. and Guest suite downstairs is great for flexibility to appeal to a wider range of buyers (ie older couples who may not want a main upstairs). However my only concern would be from a resale point of veiw that you are basically building 4x3 + study home but with only one living area. If you can I would try to wrangle some extra living/theatre somewhere even if you forgo the study and try to morph it into a space that could be study or theatre. Or try to stretch the gallery area upstairs to be a activity or upstairs lounge. Just my two cents. Goodluck Re: Need advice on my floorplan 6Sep 06, 2012 11:21 am I agree with making the walk-in pantry larger at the expense of the downstairs walk-in robe, particularly because the long windows over the kitchen bench will reduce the potential kitchen cupboard storage space. Extending the gallery outwards (lining up with the external wall downstairs, would also increase living space for probably not a lot of extra cost). Re: Need advice on my floorplan 7Sep 06, 2012 1:12 pm Also, worth making sure that the laundry chute will fit between the joists. As drawn on our original plan, the chute would have passed directly through a joist, and after the joists and frame were in we realised we needed to move it over 20cm. You don't have a lot of room to work with if you need to do something similar, so worth reminding the architect/builder about as things progress. Re: Need advice on my floorplan 8Sep 06, 2012 2:34 pm Very nice plan indeed. The walk in pantry would be a little too small thou since storage is limited for the long kitchen. Townhouse 1 would probably be better as Townhouse 2 would be quite dark inside as the it is on the south side. Both are nice and good for investment and resale i would say. 2 6423 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13833 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15253 |
