Browse Forums Lighting + Lighting Design DIY Batten Fix 12May 01, 2008 6:06 pm Hi there oznow
The DIY kits are so easy to instal. I haven't heard there to many problems with them, but i guess like any DIY, it ain't going to be like the real thing. The other downfall with DIY light battens, is that the variety is very limited. Nonetheless, i guess the DIY range has a niche market, and is doing ok. As for the safety side of things, while installing them, i'd be switching the main power to the whole house off (just incase you may have a blown bulb), and then carrying out the work. Hope this helps! do not pay until you are satisfied with workmanship windows require flashing over the head archithrave and up under weatherboards 3 28281 How much are you ahead in payments compared to where the build is at? Have you fully drawn down the loan? 5 11916 Hi All, I'm new here! I'm in a block of 4 apartments (Waverley council) and looking to change a window to a sliding door. The window faces an enclosed garden (with a… 0 5536 |
